S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
Help truly needed
Old 01-10-2016, 06:35 PM
Phamceo's Avatar
1998 s500 benz
Exclamation Help truly needed
I'm changing a ignition coil to a Bosch but the plastic stem with the spring that I need for the new one that's under the rubber boot will turn and shake but will not come out and I didn't want to break it so I couldn't change the the ignition coil has anyone else had this problem on 1998 S500
Quick Reply: Help truly needed
