S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
Pin Out wiring
Old 01-30-2016, 06:28 PM
Brian McL's Avatar
'90 500SL '07 C280 '98 E320, '19 C43
Pin Out wiring
Does anyone now how to feed 12V power to the cluster, on the bench, so it will light up all/most of the lights? Mine is out of a 1993 400SEL and has the round socket connectors like the picture. I have all 4 female plugs that I can feed power through. I just need to know which wires on the plugs to join connect to 12V. Thanks
Attached Thumbnails Pin Out wiring-dscf5374.jpg   Pin Out wiring-dscf5375.jpg   Pin Out wiring-dscf5376.jpg
Old 02-01-2016, 10:23 AM
oldsinner111's Avatar
s320
I would turn my key on,and carefully find which wires are hot in the car,to which plug.
Old 02-03-2016, 03:44 PM
Russell Ormerod's Avatar
not a merc
Did u come right?
Old 02-03-2016, 05:41 PM
Brian McL's Avatar
No...still trying to figure it out.
Old 02-04-2016, 03:10 AM
not a merc
Plug 2 pin 12 Battery supply
Plug 1 pin 5 ignition supply
Plug 1 pin 1 ignition supply
Plug 1 pin 10 ground
Plug 2 pin 11 ground
Old 02-04-2016, 10:14 AM
Brian McL's Avatar
Thanks Russell...
OK, so...Plug 1 join pin 5 and pin 1 to battery positive and pin 10 to neg.
Then on plug 2 pin 12 to positve and pin 11 to neg.....right ?
Just want to be sure before I blow it up.
Old 02-04-2016, 12:32 PM
not a merc
Correct. What I would do is connect your grounds and your battery supply direct to cluster and all the ignition supplies via a switch. That way you can simulate the ignition switch on the bench..
Old 02-04-2016, 11:28 PM
Brian McL's Avatar
Perfect...thanks Russell
Quick Reply: Pin Out wiring
