check engine light
2008 S550 4Matic and 2014 E350A Cabriolet
check engine light
I was stopped and had to floor the gas pedal to enter the freeway. Check Engine Light IMMEDIATELY came on. Car rode rough and idled very poorly when stopped at a number of signal lights. I did make it home. Question: Do I have to have it towed to my mechanic or can I try to drive it there?
Bill
Bill
Beebsie similar happened to my car with the M119 engine, you can clear the codes and drive it normally but no hard acceleration to the mechanic. Source of my issue was a bad coil which I replaced, it is an easy diy job. Good luck
beebsie (08-18-2016)
check engine light
Thanks. I did take it easy and made it to my mechanic. He replaced the ignition coil and cam shaft sensor, and I am back on the road!
