Rear cabin light lights out
01 ML55AMG 04 ML500 03 ML350 08 ML63AMG
Hi all. I got 1996 S320 was changing a bulb in the rear of the car on the sides of the cabin and i blew out the fuse in the trunk. few things stopped working like lights at the bottom of the doors, trunk soft close didnt work. After i replaced a fuse, everything works but the rear side cabin lights. the one on the middle of the ceiling works. Any idea why wouldnt they work? Thanks
Problem solved, i was trying to put led bulbs in there. for some reason led bulbs dont work there,conta ctwires just melt and burn, weird!!! So i just put regular bulbs in, everything works fine now
LED Lamps
LED lamps require a resister inline in order for them to work properly in an incandescent socket. Unfortunately, I don't recall the amount of resistance required but I am sure someone on here will know the answer. As I recall, it wasn't very high but don't want to misguide you either.
But your info is very helpful maybe if i figure out what resistor i need and how to do it i might do it. Thanks
