S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
W140 instrument lights out
Old 01-28-2017, 02:09 AM
Joel Alesch's Avatar
1991 300e 4matic, 1997 S500, 1994 Range Rover Classic
My 97 S500 sat for a few days and it did rain. I started it tonight and when I turned the headlights on the radio was making a weird buzz. When I turned the lights off the buzz stopped. Then I noticed the instrument lights were not on, or the heater control lights or the window switch lights. So no, I am sure every light did not magically burn out at the same time. All the fuses are fine. Even in the back. Side note, I had some issues with the sunroof and something else, I wiggled all the trunk fuses and a few items started working! Corrosion. Back to the dash lights. At one point I turned the lights on and off again and for a second the dash lights came on, thought it might be the headlight switch but I don't think so. On my 91 300e, years ago, I resoldered the dimmer connections and fixed the das lights on that. Watched a video on removing the s500 dash, removed the left side speaker grill, then the vent, reached in and pushed the unit out.
Quick Reply: W140 instrument lights out
