power steering pump leakage
I thought about spending $280 for a rebuilt,But for $20 I rebuild mine and put in a new filter.Easy job,just remove pulley and 6 bolts,and pull the impeller part out.Then put new seal,and O rings.Put back in pump housing and bolts.
The belts are wrinkled when you get them,and hard to put on.Put belt in your oven under 200 degrees,for 5 minutes then let cool streached out over something.
burgca (02-20-2017)
