headlights fuse or relay
Old 05-27-2005, 02:45 PM
thaiq's Avatar
Hello,
My right headlight low beam failed and after replacing with a new light bulb I still get the warning message and a non-working light(the left still work). Does anyone know if there is a separate relay/fuse for the each headlight. The owner manual only point to the fuse/relay box without any detail.
thanks
PS. it is a 2001 S430
Old 11-21-2007, 12:03 PM
Keyrat's Avatar
me: 2001 S500, 1993 K1500 wife: 2003 X5
Low beam, high beam and turn signal don't work
Guys, rather than start a new thread, heres MY problem. My passenger side headlight is not working at all. Does anyone know if theres a fuse or relay that may be causing this? Where would it be located? Thanks for your input.
Old 11-23-2007, 03:46 PM
damaged's Avatar
Enterprise rent-a-car!!!
Head lamps are controled by the front SAM units.
Left unit controls right head lamp, and right sam controls left lamp. Fuses for each are in the top of the sam. If it is a zeon lamp, check the ignitor.
Old 11-23-2007, 04:54 PM
Keyrat's Avatar
Thanks for the info. damaged. Does anyone have a picture or diagram of the SAM? I really don't have a clue what it looks like.
Old 01-15-2011, 02:51 PM
ataie's Avatar
2007 Mercedes SL550 Sport
SAM????? where andwhat is it? never heard of it. both my low beam xenon headlights are out
Old 01-18-2011, 11:54 AM
Skylaw's Avatar
2005 S500 4-Matic, 1978 450SL
You definitely need to see the "W220 S-Class Owners Start Here" sticky at the top of the forum. Scroll down to post #36 for a version of the "Encyclopedia" that is uninterrupted by people who don't read.
You will find discussion of the SAM under "Electrical System." SAM means "Signal Acquisition Module." It is in fact a kind of router for switch input, sensor input, and system operation. If you come across discussion of "Electronic Fuse" be aware that they are a component of the SAM, and they are circuits, not fuses in the common usage.
Old 05-11-2012, 10:13 PM
onlysis38's Avatar
mercedes s430
s430 mercedes low beam not working/ not bulb
s430 mercedes low beam not working and it's not the bulb. HELP!!!!
Quick Reply: headlights fuse or relay
