2000-2002 S500 Side Mirror Led Light Upgrade Before And After Picts
Rating: Thread Rating: 2 votes, 5.00 average.
Old 09-30-2006, 09:14 PM
  #101
Vader55's Avatar
AMG E55, Stage 1, Strait Pipe from Primary Cats
Originally Posted by Mark_K
OK I installed them with no problem.
They fit nice and tight and work great!
Everyone especially benznodubz (the op).
Mark
What can I do next to my 2002 S430 that not real expensive?
Taillights ? 126 bucks ?
I bought mune here.. very reliable
http://cgi.ebay.com/ebaymotors/Merce...38313236QQrdZ1
Old 09-30-2006, 09:16 PM
  #102
Vader55's Avatar
Sidemarkers here 29 bucks
http://cgi.ebay.com/ebaymotors/00-06...39270872QQrdZ1
Old 10-01-2006, 01:40 AM
  #103
gregwang's Avatar
2001 Mercedes Benz S55 AMG
Mark
How about these Factory AMG Aluminum sport pedals for $ 59.99? They're the same ones that are on the 2006 S55 and CLS55 and they not only look sporty but they grip like claws! Here is the link where you can get them:
http://cgi.ebay.com/ebaymotors/Facto...spagenameZWDVW
Also, for $ 14 more you can get the small matching emergency brake pedals. The ones from Brabus and Lorinser cost between $ 300 to $ 400 so for under $ 80 you can get all 3 pedals shipped to you and they are OEM pedals. Here is a link to a picture of it after I installed it in my car:
http://pg.photos.yahoo.com/ph/gregwa...nm=d336scd.jpg
Happy Updating my Friend!
Old 10-01-2006, 04:15 PM
  #104
Mark_K's Avatar
2002 S430
I was thinking about a shifter Knob.
Are there any nice one out there?
Mark
Old 10-01-2006, 04:18 PM
  #105
Mark_K's Avatar
2002 S430
Originally Posted by benznodubz
Why do I want these?
The yellow lights match the yellow lights you had me just install for the blinkers.
Mark
Old 10-01-2006, 04:38 PM
  #106
Vader55's Avatar
Mark
Sidemarkers are running lights.. I actually run a silver coated bulb that is burned out.. I like the euro non-sidemarker look and my car is silver so I like the look a lot specially in the day hours. It is my preference and that is what makes this so cool, we all like different things.
ps. you can run the clear side-markers and run silver coated 194 amber bulb which actually matches the sidemarker color
Once you open scroll down close to the bottom of the page
http://superlumination.com/194.htm
Old 10-01-2006, 06:52 PM
  #107
Mark_K's Avatar
2002 S430
What about changing my head light bulbs with Halogen bulbs to make it look like the lights on a newer year?
Has anyone done this?
Anyone try these?
http://cgi.ebay.ca/00-05-MERCEDES-W2...QQcmdZViewItem
Mark
Old 10-02-2006, 04:11 PM
  #108
Vader55's Avatar
Anyone try these?
Mark
Do you have actual hid's now ? If so do not buy these.. They are halogen's projectors. If you "do" have these then buy these.
http://cgi.ebay.com/ebaymotors/98-02...spagenameZWDVW
or I bought mine here
http://cgi.ebay.com/ebaymotors/99-02...spagenameZWDVW
Old 10-02-2006, 07:15 PM
  #109
Mark_K's Avatar
2002 S430
I dont know what I have!
It's a 2002 s430 standard equipent.
Anyone know what I have?
Mark
Old 10-02-2006, 08:08 PM
  #110
Vader55's Avatar
Mark
Open the hood and pull back the plastic cover on your low beam and you should see something like this ? See that square metal connector ? that plugs into your hid bulb.
Old 10-03-2006, 07:21 AM
  #111
Mark_K's Avatar
2002 S430
Thanks,
I will check it out on Friday. I am away on business every week but return on Thursday nights.
Mak
Old 10-08-2006, 03:40 AM
  #112
ksc
ksc's Avatar
S500
after debating for 6 months as to whether or not to do this mod, i finally pulled the trigger and ordered the side mirror leds.
i was hesistant because of the malfunction messages other members have encountered ,along with possible bad leds that i would need to exchange,etc. it sounded like a headache i didn't need or want.
but after installing them,i'm glad i did it because they look great;they really brighten up the look of the car. they also work perfectly,although one side did give me a little trouble at first.(the other worked fine the minute i plugged it in). the signal in the instrument cluster would blink too fast but the led would blink at a normal rate.
i just kept plugging and unplugging the connector until the blinker functioned normally. i can't explain how this solved the problem but it did.
anyway, they are working as they should. we'll see how long that lasts(a long time,hopefully). i just hope the innards of these signal lights hold up,especially the connector, as the quality
leaves a lot to be desired.
a big thanks to benznodubz for picts and instructions!
Old 10-08-2006, 05:48 PM
  #113
Mark_K's Avatar
2002 S430
I dont have HID's I have the crappy ones that came with the car in 2002.
What is different from these Halogen Projector ones and the ones I have on now? Is it just the looks like when the lights are off and you can see the little eyeball? Will the shine of the light brightness be the same?
Mark
Old 12-22-2006, 01:36 AM
  #114
Vader55's Avatar
TEXS55,
There are pics of the lights I have on this thread
Old 12-24-2006, 09:01 AM
  #115
MSackson's Avatar
00 S500 & 2008 E350 Wagon
100 Dollars for the LED lights.(EBAY) Installed them in 20 minutes.
1. Push mirror forward as seen in pict.
2. Stick thin long flathead screw driver underneath mirror(torwards front) and pry clip up so Mirror Cover housing slides off.(be careful)
3.Take mirror inside house or work area and clean up before installing new strip
4. The led strip has 2 screws that need to come out than pull out old LED strip from mirror cover...New strip will pop in
5.Once new strip is screwed in cover take back to car to plug in and mount
6.The Led strip will plug in the 2 center inputs of the 4 prong female connector located on the back of housing on car.
Let me know if you need more help.
What is the advantage of this upgrade?
Old 12-24-2006, 02:24 PM
  #116
fusion2007's Avatar
CLS 63 S AMG , s500,clk550
it makes your car look newer like the 03+ and its brighter alot brighter
Old 01-15-2007, 04:32 PM
  #117
Dragonboy's Avatar
2002 S430
Reviving old thread. I hope someone can help me. I bought a set of LED mirror sigs off ebay. Install was straight forward thanks to this site. Tested everything first and everything worked fine. A day later, I get a checklight for the passenger reflector and turn sig blinks fast. Re-installed again, now the checklight comes and goes. Contacted the ebay seller and said he was not responsible and recommended only professional installations.
Crappy product is a crappy product no matter who installs it. Nonetheless, I like the look and other than the fast blinker and resetting the error light it looks 10x better.
I know the LEDs draw a different current and all, but anyone ever fix this problem. Thanks!
Old 01-15-2007, 05:07 PM
  #118
fusion2007's Avatar
take a look at the connections this same thing happend to almost all of us the first time we installed it.. try reconnecting it and mess aorund iwth it alittle but it should dissappear after a few minutes of doing that for me it was the conection was not right.
Old 01-15-2007, 05:27 PM
  #119
Vader55's Avatar
Make sure you have the little two prong connector on your led in the very center two holes of the housing .. I belive there is 4 connecting holes on the housing make sure it is in the center two
Old 03-20-2007, 01:54 AM
  #120
Vader55's Avatar
bump for newbs
Old 03-22-2007, 04:03 PM
  #121
ray1's Avatar
Hi how you doin, I am a recent member. I have a 2000 S 500 and I just bought crystal side view upgrade from ebay. I was following your instructions on how to upgrade it, but I had no luck. when you stick the screw driver underneath the clip and pry up the clip seems to have come out but the mirror does not seem to come out. I tried everything. May be I am doing something wrong. Can you please help me out.. I would really appreciate it. thanks.
ray
Old 03-23-2007, 01:42 AM
  #122
Vader55's Avatar
ray
The mirror part does not come out.... The housing slides off it.
Old 03-23-2007, 02:49 AM
  #123
tgood's Avatar
S430
Brother you gotta live a little more. 6 months for some side markers?
Old 03-23-2007, 06:11 AM
  #124
ksc
ksc's Avatar
S500
yah , tell me about it.
for something as important as lights, i'm hesitant to use aftermarket stuff.
the quality of those signals is horrendous. you get what you pay for.
but i bought them anyway. couldn't resist. at least they look good.
i prefer oem and am willing to pay for it. 2003+ tails cost me $580 at the dealer! i know, $150 on ebay.
unfortunately with the signals, one has to purchase the whole housing, mirror, etc to upgrade. not worth the cost.
Old 03-23-2007, 10:01 AM
  #125
02S430's Avatar
W220 M113K
my tails are OEM from ebay, they have the 3 pointed star in the corner and cost $302 shipped, came in a MB box
You have already rated this thread Rating: Thread Rating: 2 votes, 5.00 average.
Quick Reply: 2000-2002 S500 Side Mirror Led Light Upgrade Before And After Picts
