2006 S350 Comand Questions
I cannot get it to where I can put phone numbers or specific addresses in the navi.. I have a 2004 ML500 where this is possible.. Why would they take the functionality out??.. Or am I just not doing it right?.. Let me know.. thank you.. AND also is it possible for the unit to play DVDS when it is stationary? Thanks
The command system requires some practice. I've noticed that with mine when I try to put in a specific address that the result is a range of addresses. For example...when I put my home in the destination memory and then left and returned....as soon as I turned the corner onto my street I am told that I have arrived...yet I am still 15 house numbers away. Other times it takes me into my driveway I am using the original DVD that came with the car (build date 1/04) and my home was built in 2000. Also I have noticed that the routing that the Nav uses is not always the most direct even though I don't have any restrictions built in to the routing parameters. I wish there was a way to force Nav to remember certain routes that we regularly travell...maybe there is and I have not figured out how to do it.
1 Post
2004 S500 & 2011 Mini JCW
Nimski, when you say DVDS do you mean a movie DVD or a DVDAudio. Either way they will play, however you will not see any video on the command head unit. I heard there was a code the the dealership could change on the head unit. However my dealer was unable to find one to change.
