Compressing Rear Piston
Got my Akebono ceramic brake pads today and was in the process of changing. Changed three wheels without any problem but on the rear passenger side I could not compress the piston on one side. Tried a c-clamp and I could not get it in there right. Tried a screwdriver but it wont move. Anyone has any tricks of doing this? Anyone?????
Well, I guess it was wrong, I forgot it had the dual rear piston brakes. Here are the instructions from the service manual. Check your brake fluid res. maybe its full and not letting any more fluid move...
Here are the directions, not that they will help with your problemo..
Remove/Install
DANGER:
Risk of poisoning from swallowing brake fluid. Risk of injury from skin and eye contact with brake fluid.
Pour brake fluid only into suitable and appropriately marked containers. Wear protective clothing and eye protection when handling brake fluid.
1 Remove wheels
Inspecting
2 Check brake pads and brake disks
CAUTION: If the brake pads are worn down beyond the permissible wear limit, the web between sealing groove and dust cap may be damaged, for this reason, check braking system for leaks using pressure gauge
3 Check fixed caliper (31a, 31b) for leaks and dust seal for damage
NOTE: If the fixed caliper is leaking or the dust seal is damaged then replace fixed caliper on front axle and replace fixed caliper on rear axle.
Remove/Install
4 Separate left front brake pad contact sensor connector (S10/1x1) and right rear brake pad contact sensor connector (S10/4x1) and pull out brake pad.
NOTE: Right and left side
CAUTION: See notes on installing brake pad wear contact sensors.
5 Drive out retaining pins (41) using a suitable drift punch (035)
NOTE: Installation: Drive in retaining pins as far as the stop using a suitable drift.
6.1 Pull brake pads (43) out of fixed brake caliper (31a, 31b)
With brake pads that move easily.
6.2 If necessary, with seized brake pads use the pressing out lever (043) to press out the brake pads.
CAUTION:
When pressing out the brake pads, insert a suitable wooden or plastic wedge between the lever and the fixed caliper.
Installation: Do not use sharp or pointed implements to clean the brake pad guides. Install front axle brake pads (43) with niro panel (43a) dry. The marking (see arrow) on the niro panel (43a) must point in the running direction of the relevant wheel.
Only sets of brake pads approved by Mercedes-Benz may be installed.
Dispose of brake pads as special waste.
Please ask local authorities if it is permitted to dispose of these parts as household-like industrial refuse.
7 Press back piston using resetting device (031)
CAUTION: Draw off some brake fluid beforehand if necessary, to prevent the brake fluid reservoir overflowing when pressing back the piston.
NOTE:
On 4-piston fixed calipers on the front axle, secure one pair of opposing pistons with wedges to prevent them from sliding out. Then press back the other pair of pistons using the resetting device.
If the piston is difficult to move then replace fixed caliper on front axle and replace fixed caliper on rear axle.
8 If necessary, clean the perforation in the brake disks
NOTE: Use a corresponding 4.3 mm dia. drift punch or drill for cleaning.
CAUTION: See notes on repairs to brake system
9 Install in the reverse order
DANGER:
Risk of accident when commissioning the vehicle due to a lack of braking effect when the service brake is operated for the first time after repair work.
Before commissioning the vehicle, operate the brake pedal several times until the pressure in the brake system is built up and maintained.
10 Operate brake pedal several times until brake pads contact brake discs (firm resistance detectable).
11 Check brake fluid in brake fluid reservoir and correct if necessary.
NOTE: Fill brake fluid to max. mark on brake fluid reservoir or suction off if necessary.
CAUTION: See notes on handling brake fluid
Copyright © 2006 ALLDATA LLC
Remove/Install
DANGER:
1 Remove wheels
Inspecting
Remove/Install
CAUTION:
NOTE:
DANGER:
