Go Back   MBWorld.org Forums > Mercedes-Benz Sedans > S-Class (W220)
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Members Insurance Search Today's Posts Mark Forums Read CarsGarageVendors
Welcome to MBWorld.org Forums
Sponsored by : My Mercedes Parts
Click Here
LinkBack Thread Tools Search this Thread Rate Thread Display Modes
Old 11-24-2006, 10:11 PM   #1
please help with my 2001 s430..problem when driving
Hi,
2001 s430 with 80k ...i was driving on the highway suddenly the car is not acclerate like it's in netural, then i shift it to netural then back to D drive again , then it's fine but the rpm went acutally higher on 60mph..it's happen to me couple times now, i also notice that after this thing happen i can't used the up and down to shift ....i have to turn off the engine and restart to bring it back to normal.does anyone know what's going on with my baby? sensor? gear box or tramisson? i hope it don't cost alot to fix it...
To remove this ad, register today or login if you already are registered!
mycbr1000rr is offline   Reply With Quote
Old 11-25-2006, 12:04 AM   #2
Drives: 04 S430 (sold),05 X5 4.4i, 02 325i, 87 560SL, 85 Alfa Romeo
Quote:
Originally Posted by mycbr1000rr View Post
Hi,
2001 s430 with 80k ...i was driving on the highway suddenly the car is not acclerate like it's in netural, then i shift it to netural then back to D drive again , then it's fine but the rpm went acutally higher on 60mph..it's happen to me couple times now, i also notice that after this thing happen i can't used the up and down to shift ....i have to turn off the engine and restart to bring it back to normal.does anyone know what's going on with my baby? sensor? gear box or tramisson? i help it don't cost alot to fix it...
YOu have to let the dealer hook up the STAR to check your car. Did it throw any codes?
This is just a stretch, but is your tranny fluid low?
Let us know.. good luck. Hope its and easy fix.
my06clk is offline   Reply With Quote
Old 11-25-2006, 12:14 AM   #3
no code..i will see if is the tanny fluid that makes the problem, what kind of tranny fluid should i used? how many qt? how often should i change it?
Old 11-25-2006, 10:17 AM   #4
kenstudios's Avatar
Get your spark plugs changed.
kenstudios is offline   Reply With Quote
Old 11-25-2006, 11:04 AM   #5
why spark plug?
Old 11-25-2006, 12:12 PM   #6
cdplayer's Avatar
Drives: 1984 500 Sec and 2001 S500
cdplayer
Hi,
I have the same year/model as you. I was able to drive my car 53 miles home from the dealer (independant) before the suspension went flat.
The car has been in the shop for 31 days. I am using a mechanic two blocks from my home to do the work. It helps that he too is a friend.
Anyway, in the course of dealing with the codes that have collected in the car, he has replaced the shifting box. Upon completion of that repair, a new series of codes were read.
He said while examining the old shifting box, he discovered the box contaminated with debris and really gummed up.
The cup holder just above the gearshift is the badboy that caused my problem. Possibly yours too.
As you can probably guess, what happens to liquids in a cup when you suddenly brake. They spill right into the gearbox. Gums up the contacts.
The selector cannot acurately read where its at.
__________________
1984 500SEC Daily driver
263,000 miles +
New smog pump
new injectors
new waterpump
new hood pad
new blower motor & resistor group
new MOMO steering wheel
new MOMO shift ****
new inside door handles L/R
new radiator
new fuel pump/filter/accumulator
new steering damper
new steering box/pump filter/hoses
new steering coupler
new rotors/pads
new oxygen sensor
new door check straps
cdplayer is offline   Reply With Quote
Old 11-25-2006, 12:19 PM   #7
how much does it cost to fix it? CAN IT BE REPAIRE OR I NEED A NEW GEARBOX? THANKS FOR YOUR HELP..
Old 11-25-2006, 01:33 PM   #8
newton22's Avatar
Drives: BMW E39
Quote:
Spark plugs??
__________________
SOLD
newton22 is offline   Reply With Quote
Old 11-25-2006, 01:44 PM   #9
the gear box
Old 11-29-2006, 08:53 PM   #10
how much is going to cost to fix this problem? the check engine light is on ,i went to a shop to reset it light, the code shows tramssion somthing ...
Old 11-29-2006, 09:13 PM   #11
newton22's Avatar
Drives: BMW E39
Post the code.
__________________
SOLD
Old 11-29-2006, 10:07 PM   #12
cdplayer's Avatar
cdplayer
Hi,
I'm in Sacramento and my mechanic (formerly a Mercedes shop manager) charges $94 an hour. The gearshift box swap takes about two hours.
However after installing the new gearbox, several codes came up that were not previously thrown with the origional box.
Above the shifter is that awesome cup holder. Really poor design (location).
What do you think happens to your drink when you have to brake suddenly?
Spills right into the gearshift housing. Over time the delicate contacts get gummed up and before long, the gearbox doesn't even know what gear its in.
The box was approx.$400 plus labor. I haven't seen the total bill yet because I am having to deal with other problems with this vehicle. The car has been in the shop now for over a month.
I have an extended warrenty but the company (Interstate) pretty much denied the claims from the get go saying my problems were preexisting. A real struggle to get these charming people to pay up. The suspension collapsed two days after I got the car home. Drove it all of 53 miles myself before it went into the shop. Dealer I bought it from, Sonoma, in Vallejo uncoperative. Soooooooooo determined to stick with it.
__________________
263,000 miles +
New smog pump
new injectors
new waterpump
new hood pad
new MOMO shift ****
new radiator
new steering damper
new rotors/pads
new oxygen sensor
Old 11-30-2006, 06:15 PM   #13
today i went back to the shop and they plug the computer into the ecu..funny there's no more code..after they reset it 3 days ago..the code was gone..they told me they really don't know what's wrong with my car...please update me how much they charge you for it...thank you
Old 12-01-2006, 06:53 PM   #14
the code is p0700.. they change the trans fluid for me but when i see them drain it, it only came out around 1 qt...this is normal?.then they change the filter, gasket and add 5qt( is this enough?).i'm start to think that maybe is low on transmission fluid..can anyone tell me when low on transmisson oil will make the car sfit unnormal? also sometime went to netural? what knid of problem will you have when the transmisson fluid is low?
Old 12-02-2006, 09:44 AM   #15
Skylaw's Avatar
Drives: 2005 S500 4-Matic, 1978 450SL
Before you get into the gearbox, have the electronic shift controller checked. I don't know the cost - mine was changed under warranty.
__________________
Warren
2005 S500 4-Matic with
Gateway 500 iPod integration
1978 450SL restoration project
Formerly: 2000 S500 with
Ice>Link Plus iPod integration,
MikBox, and Upgraded voice control
Skylaw is offline   Reply With Quote
Old 12-02-2006, 12:36 PM   #16
electronic shift controller where does it located? wil that give p0700 code? what kind of problem will have if is low on transmisson fluid..before you change the shift controller do you have the same problem that i got? also any code?
Old 12-02-2006, 09:17 PM   #17
..Another cause could be the conduit electrical seal on the transmission, which could soak the trans control unit(not sure if it's TCU) in ATF. I would change the transmission fluid too, since the trans could be low on the fluid that should have been changed at 60k mi.
I think it's better to go this route than look into the gear shifter, since gear shifter is more expensive.
Hope this could help you..!
Darknessph is offline   Reply With Quote
Old 12-03-2006, 12:56 AM   #18
how can transmisson fluid be low? i thought mercedes manuel said it never needs to be change? i never change my, it's 90k now and this is the fisrt time , it only drain out 1 and half qt. of fluid..is this normal? or is there a leak some where? also my driver side front suspison makes squzze noise but runs perfectly fine..anyone might know what's wrong? thanks for your help..
Old 12-03-2006, 06:38 AM   #19
Your Front right suspension noise is likely the lower ball joint, if not, the control arm bushing that joins the sub frame would be the culprit. Could be both.
Do some search about "transmission fluid" on the forum, and you'll see why you need to change the fluid. Although I haven't done any trans fluid change since mine was new, I'm only at 55k miles right now. I am planning on changing mine very soon.
The reason why you could be low on transmission fluid is- that the transmission fluid could leak out through the electrical seal gradually over time. Moreover, the low trans fluid issue could really stand out when you take corners as the fluid fluctuates to one side of the transmission.
Old 12-03-2006, 01:22 PM   #20
thank you ..i'll check to see if is the control arm and ball joint...so is normal that my 2001 s430 with 90k only drain out 1 and half qt. of transmisson fluid..right cause i never change it before..and the low fluid cost the coded p0700 too then..
Old 12-03-2006, 02:43 PM   #21
you should be able to drain out about 3~3.5qt just by dropping the pan.( have done the work on my previous 98 SL500) you also need to drain the torque converter. When you drop the pan, you also need to replace the pan seal & AT filter. When you drain the torque converter with pan drop, you should be able to get 8~9 qts of ATF. :-)
Old 12-03-2006, 03:11 PM   #22
they only drop the pan and place the seal and the filter, it only came out like 1-2 qt. the most.. is this mean i might have a leak somewhere.. my mechanic don't know how to change the oil on the converter..
Old 12-05-2006, 06:04 AM   #23
fkong777's Avatar
Drives: 07 GL450, 91 NSX, 12 Prius
I've notice my tranny is occasionally dripping fluid.. and I feel it shift once in a while hard. it drips from a Cable o-ring at the tranny. Just never got it to a dealer to check.
BTW to your earlier question. Yes low fluid will cause slow and hard shift. So erratic shifting can also be a symptom.
To change the converter ATF you basically have to do 2 to 3 rounds of ATF change. each round should be 500 miles apart or more. ATF circulate in the tranny and torque converter. However MB stealership tech should have a pump that will circulate all the old ATF out then refill with new ones.
__________________
07 X164
91 NA1 NSX MT
12 Toy Prius
02 W220 S430 (Sold), 00 W163 ML55 AMG(Sold),
fkong777 is offline   Reply With Quote
Old 12-05-2006, 10:31 AM   #24
mine was drips from a Cable o-ring at the tranny too..it's like leaking from a wired that plug to the tranny..is that the same problem you got? have you get it fix yet?
Old 12-05-2006, 12:17 PM   #25
whoover's Avatar
Drives: '06 S65, '06 C55
That leak is a well-known problem that involved a recall.
http://www.alldata.com/tsb/Mercedes-...8C/200081.html
whoover is offline   Reply With Quote
Tags
2000, 2001, cup, design, holder, noise, plugs, poor, remove, replace, s430, shift, spark, tranny, transmission, w220
Search this Thread:
Advanced Search
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Copyright © 2001-2012 InternetBrands, Inc. / MBWorld.org. All Rights Reserved.
Everyone's Personal Details
SEO by vBSEO 3.5.2
