Acceleration Problem
Rating: Thread Rating: 3 votes, 5.00 average.
Old 11-07-2007, 11:02 PM
StephenK's Avatar
2006 SL600, 2001 S500, 1996 SL320
Have a problem with my 01 S500 today. When I press the gas peddle nothing happens for a few seconds then the car will go, I can press the pedal to the floor and nothing, but once it starts going it is fine. If I keep pressure on the gas peddle it accelerates no problem, but it I take all pressure off the pedal, when I press it again, it takes a few seconds before the car wants to go.
Strange one to me, the car is not actiing like it is going to stall, just a delay in acceleration.
Any ideas?
Old 11-08-2007, 01:11 AM
whoover's Avatar
'19 E63S sedan
Sounds like the accelerator pedal module is going. Very common problem with this car at about that age. Do a search. The part is $200 and is easy to replace yourself.
When it goes the transmission and engine control units get contradictory information about pedal position. You wind up starting in fifth gear. If that's what it feels like you're experiencing, try replacing that part first. If it's not the problem, you've just saved yourself another failure in the future.
Old 11-08-2007, 02:01 PM
NazarKmet's Avatar
2010 Mercedes S400
Hi how are you. I have a same problem, Is any body know how to replace the accelerator pedal module. Thank you.
Old 11-08-2007, 04:27 PM
whoover's Avatar
'19 E63S sedan
Mine was done on warranty so I don't have first-hand knowledge, but I think there's a single nut holding the accelerator module to the firewall. The nut is under a cap. You swap the electrical connector and are done.
Old 11-08-2007, 04:54 PM
NazarKmet's Avatar
2010 Mercedes S400
Where the module located? Under the hood or in trunk? Sorry I don't know. Thank you.
Old 11-08-2007, 05:15 PM
whoover's Avatar
'19 E63S sedan
It's the pedal assembly itself. The thing you step on. Your foot operates an electronic module that runs the drive-by-wire.
You replace it in the driver's footwell.
http://www.detali.ru/cat/oem_mb2.asp...SGR=015&SGN=01
Old 11-09-2007, 11:57 AM
NazarKmet's Avatar
2010 Mercedes S400
Thank you. I went to the dealer around me they ask $400 for it the parts it self is $178.80 Parts number 220-380-00-07 on ebay you can get for $90.
Old 11-14-2007, 04:01 PM
Paul Wall's Avatar
2004 SL500 2001 S430 1998 SL500-sold 1986 PORSCHE 911-sold
Any ideas?
I had a similar problem with my S430 and it turned out to be a short in the gas peddle (its electronic rather than a direct connection). Good Luck. Paul
Old 11-15-2007, 12:48 PM
StephenK's Avatar
Installation?
Is it just a matter of changing the pedal assembly? or does the car need to be used up to the computer???
Old 11-15-2007, 01:02 PM
whoover's Avatar
'19 E63S sedan
Just plug and go.
Old 11-15-2007, 02:02 PM
JRAMGV8's Avatar
1999 C280 Previous / 2008 E350
I wasn't aware of this.. good info.
Old 11-15-2007, 02:04 PM
StephenK's Avatar
Getting the part
Getting the part, and will be able to give you my personal experience with it a little later today. Hope it works!!!!!!
Old 11-15-2007, 03:14 PM
StephenK's Avatar
Problem Solved
Got the part:
Simply take a plastic cap off, then undo the bolt, disconnect two connectors, old assembly comes out. Simple reinstall
Takes all of about 10-15 minutes.
Old 11-15-2007, 03:55 PM
whoover's Avatar
'19 E63S sedan
Glad it worked for you.
Old 11-16-2007, 03:49 PM
Oddemann's Avatar
MB S320
Hello
If this didnt solve your problem, you should start looking at your O2 sensors.
Rgds
Odd
Old 11-20-2007, 06:40 PM
2H S5's Avatar
2011 Sienna SE, 01 S500, 05 LS430 UL
Thanks to you whoover, my same problem was solved and was going to do a DIY for the members. Seems like Stephenk beat me to it
BTW, part # is: 220 300 00 04 as seen on the box (not 220-380-00-07)
Dealer told me it couldn't be the accelerator pedal and was adamant about the transmission
Another independent shop told me it could be the actuator ( a $600 part)
I bought it at a local mercedes shop for $150 with tax and replaced it in 15 minutes also.
Thanks again whoover
Old 11-20-2007, 07:52 PM
whoover's Avatar
'19 E63S sedan
That's great. I'm glad it worked out.
Old 11-26-2007, 11:46 AM
sdixon's Avatar
2001 S430 (w220)
Thanks for the info. I have a s430 and I had the same problem. My ODBII reader was giving me an error code of "p0120" but I could not figure what sensor that was or where it is located. I will now go and look for this part. Has anyone else also had the same error code and changed this sensor out? Thanks again. Everyone has been helpful.
Old 11-26-2007, 11:58 AM
StephenK's Avatar
What is this ODBII reader??????
Also I came across this site never ordered anything, but you may want to check it out.
http://www.oempartsdirect.com/
Old 11-26-2007, 01:39 PM
newton22's Avatar
BMW E39
http://en.wikipedia.org/wiki/On-Board_Diagnostics
Relevant to all cars manufactured around after 1996.
Old 11-26-2007, 03:27 PM
whoover's Avatar
'19 E63S sedan
Yep, the P012x codes are throttle position. It would be the most logical code to be thrown when the accelerator module packs up. But I've heard that, depending on exactly how it fails, it can throw a host of odd codes, including false transmission codes. This is because the TCU and ECU get conflicting input as to engine speed.
Like I said earlier, just drop in a new pedal module. If it isn't the problem you can be confident it will be some day soon. But it's usually the problem.
Old 11-26-2007, 03:30 PM
sdixon's Avatar
2001 S430 (w220)
Thanks. I really appreciate your help and I am shopping for the part as we speak. Have a good one.
Old 01-18-2009, 11:12 AM
awdrock's Avatar
03' S430
Great info everyone.
My 01' S500 does the same thing from idle to acceleration.
Another thing I noticed is that when im driving if I floor it, its a slug, the motor feels like it has no power because it feels as its in the wrong gear, even upon pressing the "button" on the bottom of the pedal position. Happens at any speed.
Could this also be related to the same pedal module???
Old 01-18-2009, 11:35 AM
whoover's Avatar
'19 E63S sedan
Sounds like it. I'd just replace it. It's about a 5-minute DIY and in the rare event it isn't your problem you've avoided a future on.
Old 01-18-2009, 04:04 PM
ibeforreal's Avatar
2003 S500 - Toyota Corolla (in the rain)
A similar problem to what I have on occasion. Sometime when I punch it, the transmission doesn't fully engage. Only happened twice. However, I cut the car off, restart it and everything works fine. The only problem is when I'm on the interstate pulling over to restart the car is not pleasant and kind of embarassing. Thanks for the info.
You have already rated this thread Rating: Thread Rating: 3 votes, 5.00 average.
Quick Reply: Acceleration Problem
