2003 s430 side marker lamp replacement
My left front sidemarker lamp needs to be replaced. Is this a complicated process to remove the lense and replace the bulb. Thanks in advance.
2005 S500 4-Matic, 1978 450SL
No, it is dirt simple. Gently pry the lens cover from the end. I used a utility knife wrapped in cloth, but the cloth was probably overkill. I pried from the edge toward the rear of the car.
The bulb is easily reachable under the lens.
I just did it to my 2003 E-500 pry from the back of lens at the same time pull towards you pops right out. I used a eyeglass flat head screwdriver.
Thanks for the info Warren
