KEYLESS GO SYSTEM
Old 04-25-2008, 04:44 PM
reagentjimc's Avatar
2005 sl500-2002 ml500-1998 sl500
KEYLESS GO SYSTEM
DOES ANY KNOW IF YOU CAN TELL THE DIFFERENCE VISUALLY BETWEEN
A NON KEYLESS GO SMART KEY A KEYLESS GO SMART KEY
Old 04-26-2008, 09:25 PM
DeadPresident's Avatar
2003 S600
Keyless Go
I have Keyless Go and the key is the same as any Benz. It is the credit card sized smart key that enables keyless go. I have two standard keys and two credit card shaped keys that allow keyless go and lock/unlock to function.
Old 04-27-2008, 02:20 AM
jd986s's Avatar
You cannot tell the difference between keyless go key and standard key by looking at it. However, Keyless go key has 1 battery and standard keys has 2 batteries.
Old 04-27-2008, 11:20 AM
KEYLESS GO 2005 S500
THANKS FOR REPLY DEAD PRESIDENT
I DONT THINK 2005 USE THE CARD FOR KEYLESS GO-BUT NOT SURE???
Old 04-27-2008, 11:25 AM
KEYLESS GO 2005 -S500
THANKS jd986s
I HAVE 2 KEYS- 1 WITH 1 BATTERY AND 1 WITH 2 BATTERYS-NEITHER WORK
Old 04-28-2008, 10:34 PM
tbonestk's Avatar
2005 S500 4MATIC
I have a 2005 S500 4MATIC, but it doesn't have the Keyless Go equipped. Although the manual talked about Keyless Go, and there's supposed to be a button on top of the Gear Selector Lever (page 34 of the manual). However my car doesn't have that button at all.
Was this an option at the time or did it come as a standard feature?
Old 04-30-2008, 03:34 PM
MY S500 HAS START BUTTON
VEHICLE DEFINETLY HAS KEYLESS GO -SAYS KEY NOT RECONIZED WHEN I PRESS ON BUTTON
I HAVE READ WHERE YOU ARE SUPPOSED TO LEAVE KEY IN IGNITION FOR SEVERAL DAYS???????
CANT IMAGINE THIS!!!
Old 04-30-2008, 03:36 PM
KEYLESS IS AN OPTION
I THINK ITS ABOUT A $1100.00 OPTION
Old 04-30-2008, 04:07 PM
DRTYLNDY's Avatar
You don't need the key for the keyless go system to work. There is a credit card size transmitor that is dedected when it is within 3 feet of the car. Then you get in push the brake and hit the button then she starts. It is a fantastic option. I haven't used the key since I bought my S55!
Old 04-30-2008, 04:26 PM
kenstudios's Avatar
It's not hard to know if you have keyless go or not. If you have all these three then you have it. If you have it and it doesnt work, then your key needs to be reprogrammed. Visit your dealer for a sure fix. Credit card type keys were last used in 2003 after which MB switched to the regular looking key.
Attached Thumbnails KEYLESS GO SYSTEM-keylessgo.jpg   KEYLESS GO SYSTEM-keylessgo-001.jpg   KEYLESS GO SYSTEM-keylessgo-002.jpg
Old 04-30-2008, 09:17 PM
jd986s's Avatar
Credit card is for an older system. 2005 keyless go looks like regular key. It's the one with one battery. Dealer needs to program keyless go for you. You cannot leave key in the ignition for programming. Take the key with one battery to your dealer to program. Hopefully your car is still under warranty.
Old 04-30-2008, 09:40 PM
my06clk's Avatar
04 S430 (sold),05 X5 4.4i, 02 325i, 87 560SL, 85 Alfa Romeo
I am assuming your keys work in the ignition right?
If so, and you recently purchased your car, then the answer is simple.
Whomever had the car before you bought a new set of keys and had them programmed. The Keyless Go key looks like the other key, but it has different transmitter on the circuit board.
Therefore it is entirely possible to order a replace non keyless go key for a keyless go car and it will work in the ignition.
If your keys start your car from the ignition, then they are programmed.
You will need to get your dealer to get you another set of the correct keys.
Otherwise your keyless go system could be malfunctioning.. That's not probable, but I wouldn't rule it out.
YOu can only solve this mystery by taking the car and the keys to the dealer and having them diagnosed.
Old 05-01-2008, 06:52 AM
DRTYLNDY's Avatar
So does anyone know if I could get one of the new keyless go keys for my 2003 with the older system to elimainate the card style transmitor?
Johan
Old 05-01-2008, 07:03 AM
my06clk's Avatar
Johan
Yes you go to the Dealer and ask for a Key. Those credit cards were no standard. In other words when you ordered Keyless go you had the option to use the card or the keys or both. the cards weren't very popular so they were phased out all together. There is always a key version available.
Old 05-04-2008, 06:00 PM
KEYLESS GO PROBLEM SOLVED
THANKS MY06CLK
ACCORDING TO DEALER VEHICLE ORIGNALLY PROGRAMMED FOR 2 ORIGNAL KEYS ONLY WHICH DID NOT HAVE AS PURCHASED THRU ESTATE SALE
NOW DEALER PROGRAMMED FOR 2 REPLACEMENT KEYS
Old 05-05-2008, 10:19 AM
DRTYLNDY's Avatar
So that means my key should work the same as the card for keyless go. I will have to go check it out. Thanks
Johan
Quick Reply: KEYLESS GO SYSTEM
