Airmatic system continues to leak - help appreciated
Old 09-25-2014, 03:36 PM
tusabes's Avatar
Mercedes
What he said . You're either abc or airmatic , not both. I think you're abc in the 2007 s550
But you are posting in the wrong forums , this subforum is for the w220 chassis up to 2006
2007 cars are the w221 chassis and they have a separate subforum here
Old 06-29-2015, 09:25 AM
gdemus's Avatar
2003 s430
Air Suspension S430
Guys: I have 03 S430 Great Car!!! 2 weeks ago it started dropping down on all four after 3 hours of sitting. It will lift automatically when I crank it up. I haven't been driving the car because I do not want to burn up the compressor. I'm pretty intelligent when it comes to fixing most thing, so I feel this is something I can repair myself, From what I have researched on MB world and other site its either the compressor or suspension valve. My question is is there anything special I need, and when Jack the car up do I need to jack up all four wheels so it is level and with the car in the air will I steal be able to find/locate the leak since there will not be any weight on the suspension system? Your help is appreciated.
Old 01-29-2016, 01:10 PM
cjdavis63's Avatar
w22 s class
Can anyone advise me on a 2000 s class with leaky air suspension. Guy wants $2500.00 but the radio doesn't work, ac not cold and all for shocks are bottomed out. Says he can hear the pump run. Is this a good price in your opinion and can anyone direct me to a diagram that shows all of the component locations pertaining to the air shocks?
Old 01-30-2016, 02:38 AM
tusabes's Avatar
Mercedes
Not a good deal
You'll spend over $2000 to repair airmatic then you'll be at $4500 for a car with other problems
and potentially several hundred /few thousand to get radio and AC working . Also the car probably has water damage that's why radio and AC went out
You have already rated this thread Rating: Thread Rating: 2 votes, 5.00 average.
Quick Reply: Airmatic system continues to leak - help appreciated
