AIR FILTER
2005 S500 4-Matic, 1978 450SL
Welcome to the forum; the search tool is your friend.
See https://mbworld.org/forums/s-class-w...placement.html to change the cabin air filters. I don't have the other filter change bookmarked, but a search will probably find a post.
96 and 08 911 turbos
1. remove black intake tubes by pulling towards front of car.
2. lift black plastic cover with mb logo.
3. Lift main engine cover and remove from car.
4. Flip over, loosen 4 torx screws on each airbox.
5. remove filter, clean airbox out, and reinstall new filter.
6. hand tighten the torx screws
7. replace main engine cover making sure its seated on maf connection gasket
8. push black intake tubes back on
9. replace front engine cover.
Id wager that I could complete this task in about 10 minutes if I had someone to hold the airbox while I used a speed wrench on it.
