Sign in using an external account
| S-Class (W220) 1999-2006: S 320 CDI, S 320, S430, S 500, S 600
Sponsored by : My Mercedes Parts ![]() |
LinkBack | Thread Tools | Search this Thread | Rate Thread | Display Modes |
#1 | ||
Drives: '02 S55
A/C Problem - Climate Control Unit
#2 |
Drives: '06 S65, '06 C55
All MB repairs are warranted for 1 year. The dealer should interpret the climate control diagnostics and confirm the failure. The system shuts down (which is what the LED is telling you) whenever internal pressures aren't right. It's often a valve or pressure sensor, but can be a leak or any of a number of other problems. The odds are that it's not the electronics again.
#3 |
Drives: '02 S55
Thanks Whoever ... I should have know that
![]() I see people in my business jump to stupid conclusions all of the time! Also, I didn't realize there was a 1 Year waranty, so now I am hoping it is the same problem abd it was just a defective replacement and not a chronic electrical problem or something new. Funny how things change. Anyway, you are probably right and it is unrelated. Thanks |
#4 |
Drives: 05 S500 4m
Run climate control diagnostics to check for codes. If there are no codes, run through the different parameters and check for any that don't make sense.
The 210 forum, sticky section at benzworld.org has good info on how to access this info. I know how to get to parameters (both temps at 72, hold rest button, then use temp buttons to scroll through), but I can't for the life of me remember how to get to the codes.
__________________
05 S500 4m & 96 993TT |
#5 |
Drives: '02 S55
Thanks OliverK
I pulled the values as you suggested 0 - 9,1 C 1 - 11,7 C 2 - 0,0 C (it was 32 F outside) 3 - 29.5 C 4 - 13.0 C 5 - 3,8 C 6 - 36 C 7 - 2,0 bar 8 - 2,0 C Sensor 7 is at 2,0 bar ... I would guess this is refigerant pressure and this would be the one I would care most about? I looked over at the other forum and after some experimenting came up with this to get the codes ... Left temp at HI, right temp at LO hold the rest button and activated Charcoal filter button for 5 seconds I got a message that looked like Searching ... then after 5 more seconds DIAG KLA V ERROR 1298 Last edited by miken1799; 02-28-2009 at 09:13 AM. |
#6 |
Drives: 05 S500 4m
From what I recall, it appears that you are low on refrigerant.
I'd have a chat with your mechanic and look for a leak. It seems that all auto a/c systems leak a little, so unless its major, I would try just adding refrigerant for now.
__________________
#7 |
Drives: S500 W220 1999
I think 1298 is rear temp evap sensor. Please note you evap temp sensor front is reading low which could mean it is peforming ok, also your heater temperature for one side is 13C which is ok. The pressure is low, however these systems can vary pressure to suit. Your outside temperature is very cold so it is difficult to test under these conditions. I am concerned that the climate control light is lit again after a short time. The climate control unit may not have been the problem. If there is a leak I would check behind the left (driver) wheel arch if you have rear evap unit as there is a solenoid there which had aleak on my S500. If you have heard hissing sound from center vents in the summer then gas is low. Error codes can give the wrong impression with a system so becareful with diagnosing using these values.
#8 |
Guys, while we can access the codes, is there a way to reset the climate unit DIY? (On an early '99 430)
I ask as i have been having problems with my fan motor recently, and while playing with it disconnected it from the regulator which caused the EC light to come on perminently. It was due a service anyway, so while in they simply reset this for free and its been great since. However, like a total fool i have just done the same thing this evening Wondering if i can save myself a trip to the dealer?
__________________
#9 |
Drives: 2002 s500
2002 s500 AC problem
Thank you for the info posted on this site - I was able to fix an Air Conditioning problem by reading the conversations related to someone else's issue - my "AC off" button (red light) would not turn off and the compressor would not engage so there was no cold air. By setting the left temp to "HI" and the right setting to "LO" and then hold down "REST" and the "Charcoal Filter" button down at the same time for approx 5 seconds, I was able to see 3 error codes (toggle the error code by using the right temp setting button). Once I pushed the two round "Auto" buttons (this button also changes the air flow positions) - by doing that it reset the codes and my AC started to operate normally - I think the problem started when a radiator hose popped and an auto shop replaced it. This was in the winter so I didn't notice the light on for 3 weeks and I think they may have unplugged something and created a problem. Now one of two things will happen, this will continue to work and life goes on or the light will come on again and I will now know the problem is its not with the controller (that MB dealer told it was - $1000 repair). Now I will be able to research the error code my self and be an educated consumer.
Does anyone know where I could find the error code list? 1458 = Right Foot Well Flap Actuator 1464 = Right Center Flap Actuator 1256 = Evaporator Temp Sensor Front Last edited by hedalan; 06-06-2011 at 09:36 PM. |
#10 |
Drives: Cl 500 2003 model
Guy I want to thank you as well it was very helpful
#11 |
W220 AC / Heating control error codes and how to reset
I used these for my 2004 S430 4MATIC sedan. Good reference. Hope this helps!
W220 S430 AC / Heating control error codes and how to reset 1) Set the car in park and turn on the engine, hold the rest and particle filter buttons down together for about 5 seconds (The screen will show searching) 2) This screen gives you the fault codes. If you're curious, scroll up and down to see them using the temp up and down switch. 3) Pop out the left auto vent button and right auto vent button. 4) Now press the the left button in, and then the right one. The system will reset. 5) Turn the car off, wait a minute, then turn it back on again. If you don't have any further problems, the light should stay off. (If it comes back on again, you have more things to do) Some of the possible error codes: B1000 Control unit N22 (AAC pushbutton module) is defective. B1022 Fault in CAN communication w/ control unit ESA-FL (Electrically andjusted front left seat) B1023 Fault in CAN communication w/ control unit ESA-FR (Electrically adjusted front right seat) B1053 Fault in CAN......DCM-RR (Door control module rear right) B1054 Fault in CAN......DCM-FR (Door control module front right) B1055 Fault in CAN......DCM-FL (Door control module front left) B1056 Fault in CAN......DCM-RL (Door control unit rear left) B1057 Fault in CAN......OCP (Overhead Control Module) B1059 Fault in CAN......SAM-FL (Front Left Signal Aquisition Module) B1074 Fault in CAN......EIS (Electronic Ignition Switch) B1075 Fault in CAN......SAM-FR(front right Signal Aquisition Module) B1076 Fault in CAN REAR SAM (Rear Signal Aquisition Module) B1087 Fault in CAN......TSTH (Stationary Heater) B1088 Fault in CAN......ICM (Instrument Cluster Module) B1219 N22b1 (In car temperature sensor) B1228 B10/2 (Left heat exchanger temperature sensor) B1229 B10/3 (Right heat exchanger temperature sensor) B1230 B10/6 (Evaporator sensor) B1241 Refrigerant Level is too low B1256 B10/6 (Evaporator temperature sensor) Evaporator front B1257 Refrigerant pressure is 0 bar B1267 Communication Fault of A/C bus B1268 Communication fault of A/C bus w/ control unit N18/4 (Center vents electronic control module) B1269 Communication fault of A/C bus with control unit B31/1 (AAC multi function sensor) B1270 Communication fault of A/C bus w/ control unit B32/2 (AAC sun sensor (4 in total) B1271 Communication fault of A/C bus w/ control unit N22/5 (Stepping motor electronics control module) B1298 B10/6 (Evaporator temperature sensor), Evaporator rear) B1417 A31y1 (left duo valve) Heater valve B1418 A31y2 (right duo valve) Heater valve B1424 A32m2 (activated charcoal filter flap adjustment motor) B1434 Voltage supply of A/C bus B1451 M16/17 Left center vent diverter flap actuator motor B1452 M16/19 Left center vent temperature regulating flap actuator motor B1453 M16/21 Fresh air and recirculated air flap actuator motor B1455 M16/13 Left defroster nozzle flap actuator motor B1456 M16/14 Right defroster nozzle flap actuator motor B1457 M16/15 Left footwell flap actuator motor B1458 M16/16 Right footwell flap actuator motor B1463 M16/18 Right center vent diverter flap actuator motor B1464 M16/20 Right center vent temperature regulating flap actuator motor. B1849 Fault in CAN communication with control unit N22/4 rear A/C control unit |
| Tags |
| 01, 11, 220, 830, 85, ac, climate, control, low, module, refrigerant, reset, s500, sympton, unit, w220, working |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Display Modes | Rate This Thread |
