Windshield Washer not working!!!
'05 S430 4MATIC Sport, 2009 GT Zaskar MTB
My windshield washer system is not working. The wipers activate after depressing the control, but the pump doesn't work. Headlight washing is working though. Any idea what could be the problem? Do you know where is the fuse located?
Right Hand Fuse box fuse #10. Mine is doing the dsame thing but do not have the headlight washers. I have replaced the motor and checked fues and line voltage with no avail. Good luck and msg me back if you get an answer. Thanks.. James
Believe it or not, but my washer is working. The problem was me! I was not depressing the control enough.
Sorry and thank you for reply. I hope you figure out your issue as well.
Glad it worked out for both of you. JL another thing that will freak you out if you haven't tried it already is the "summer mode" or something like that. Just hold down the unlock button on your key fob and all of the windows and sunroof top will open. Hold down the lock button and they will all close.
The option that John B is talking about requires that you hold the key fob so that the IR (infaRed) window on the end of the fob points at the IR window on the rear end of the front door handles from near range.
(No affiliation)
I have one, best money ever spent on car.
