OFFICIAL: w220 Wheel/Tire THREAD!
#52
1 Post
W220 S500, CLS63 AMG Weistec Stage III, N54 BMW 335i FBO
My 2000 S500 with factory Mercedes-Benz W219 CLS63 AMG wheels. I am running no wheel spacers and the car is lowered. When I installed these several years ago they did rub slightly in the rear however after a little rolling no issues.
Specs:
Front
Tire Size 255/35/19
Width 8.5Jx19
Offset ET25
Rear
Tire Size 275/30/19
Width 9.5Jx19 ET28
Specs:
Front
Tire Size 255/35/19
Width 8.5Jx19
Offset ET25
Rear
Tire Size 275/30/19
Width 9.5Jx19 ET28
#54
They look like S65 wheels. If they are factory S65 wheels the offset on the front is fine but the rear offset will be 60.
#55
#56
A15mm spacer would take it back to stock for a non S65. I am no expert on spacers but I would guess longer bolts would also be needed.
#57
#58
Also I do NOT need to get the $200/each tpms sensors right? My understanding is my existing sensors will carry over as theyre the bolt on
#59
Sorry for the late reply, been traveling. I replaced the TPMS sensors with my last set of tires about 2 years ago. They were still original and the batteries were failing after 7 years. As I recall they cost about $65 each at Tire America (Discount Tire) with the new tires.
One other point on the TPMS. The units changed over time. The receiver in the 2004 may have used a different frequency than the 2006. Your installer should know or be able to look it up.
#60
#63
Supreme Respect
Please tell me what they are brand ? Or if anyone knows of any replicas I would be so appreciative of any assistance anyone could offer..
JPLandolt (10-15-2016)
shadowt45 (03-02-2018)
#65
2001 w220 offset range
Need help i own a 2001 w220 and im looking into the vossen cv3r but i need the correct offset for my car ill be running 20x9 front 20x10.5 rear ill willing to change the with i jist need help with offset asap thanks in advance
#66
many rims use a 30 or 35 offset which will stick out too far
#68
It took some time but i finaly managed to get some rims for my w220 in norway, ended up with used kleemann ts-7. 9x20 front, 10,5x20 rear, 245/35/r20 and 285/25/r20. Very happy with the result, now i just need to lower it about 2cm with links front and rear, and i need to fix some small gutter rash on 2 of the kleemann rims
#69
Getting rims for my s600 and still scratching my head on tires. Rims are 9x20 front and 10.5x20 rear. The manufacture would offset it based on model of car. Tires im looking at are 245/35/20 Front 275/30/20 for rear, or going a little thicker 255/35 front and 285/30 rear. Any recommendations ?
you will need to trim the plastic rear bumper tabs if they rub
