A/c red light on =?
Old 12-12-2010, 05:36 PM
chris911carerra's Avatar
s320cdi
A/c red light on =?
AC light ON means A/c off right? why cant i turn my light off? button just does nothing although red light is on ... is this right?
Old 12-13-2010, 07:54 AM
DRTYLNDY's Avatar
The red light means the a/c is on not off.
Old 12-13-2010, 09:45 AM
Fraser's Avatar
A Mercedes obviously!
Sounds like what I had a few months ago, no matter how many times you press it the AC OFF light won't go out. It's a bad sensor in the AC system, IIRC it's the hydroactive pressure sensor but I'll check my invoice when I get home if you like. It won't be an expensive fix. For labour and part it was $280 at the dealer.
Old 12-13-2010, 11:34 AM
s320cdi
so to confirm .... the light on means the air con is turned ON?
Old 12-13-2010, 11:49 AM
ohlord's Avatar
To confirm
the ec light on and not being able to shut it off means the ac is not on.
Usually low r134a and the sensor shuts down the compressor for protection.
If you have digital climate control see if you can run the onboard diagnostic program for the ac if your model allows it.
Otherwise any good ac shop can check for leaks and refill the system.
Old 12-13-2010, 12:04 PM
Fraser's Avatar
No, it's an 'AC OFF' light, so if the light is on the AC is not working.
Old 12-13-2010, 12:05 PM
s320cdi
thank you for reply!
will contact the air con man !
Old 12-13-2010, 12:24 PM
bob55's Avatar
2013 SL550 (Lux Sport), 2006 CL55 AMG (Muscle). S550 (Wife's Sedan)
You can shut off just the A/C without shutting down the rest of the heating ventilating system using the A/C "off" button. If the light remains on, your car has a malfunction.
Old 12-13-2010, 12:26 PM
s320cdi
yes but it does nothing! the light stays ON
Old 06-17-2011, 11:20 AM
highonpsi's Avatar
2007 E550 4Matic
I have the same problem on an '03 S600. The red light is on and stays on no matter what I do. I could only find instructions on how to get diagnostic on a w210 chassis. Anybody know the procedure for diagnosing through the push buttons on the climate control for the 220's?
Old 07-07-2014, 07:13 PM
nickss55's Avatar
S55
Where are you located at have this problem 484-843-3899 nick
Old 07-07-2014, 07:14 PM
nickss55's Avatar
S55
04 s55
[QUOTE=nickss55;6094841]Where are you located at have this problem 484-843-3899 nick
Old 09-11-2015, 06:32 AM
saeed_mohmd's Avatar
2002 c200
My Issue is solved:
I was having EC light on in my 2002 C-Class so compressor stooped working...
I added gas but still light is on...
I made doaa (prayer) to allah to help me solving this problem.
Then I opened the front panel and removed the AC unit out and unplugged it from the wire harness.
Then I opened the unit itself and cleaned it by air then reconnect it again.
Then it is worked and the light goes and compressor started again...
alhamdulellah
Old 09-29-2015, 11:48 AM
2710Pocahontas's Avatar
2004 Mercedes s500 4matic
Well, I think you probably cleaned the charcoal filter by blowing it out. Good going!
Old 10-30-2023, 05:12 PM
JDH1's Avatar
2003 Mercedes sl500
on a 2003 Mercedes' sl500 the button says ac off if the red light is on the ac is off.
Old 10-30-2023, 05:15 PM
JDH1's Avatar
2003 Mercedes sl500
Old 10-30-2023, 08:14 PM
kraut56's Avatar
2009 E350 4M Avantgarde;mistress 2002 S600; wife 2014 C300 4M
If the AC red light stays on no matter what, it is an "unrecorded " error in the software, that can be fixed.
Search my statements on this here and "there" under my nick.
Quick Reply: A/c red light on =?
