Go Back   MBWorld.org Forums > Mercedes-Benz Sedans > S-Class (W220)
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Members Insurance Search Today's Posts Mark Forums Read CarsGarageVendors
Welcome to MBWorld.org Forums
Sponsored by : My Mercedes Parts
Click Here
LinkBack Thread Tools Search this Thread Rate Thread Display Modes
Old 04-09-2011, 11:38 PM   #1
Drives: 2000 S500
2000 S500 Sitting Super LOW. Airmatic Issue
Hi there, this is my first post so here goes. I know this issue has been talked about extensively in these forums but I havent been able to find out a true fix.
I just bought a 2000 S500 with airmatic this week. The car is beautiful and only has 46k miles. Every morning when I go out to the car it sits super super low on all fours. Almost as if the tires are touching the inside aprons. When I unlock the door it starts to raise and after I start it it takes only 30 seconds to get to normal height. I don't have to push the button.
It takes about 6-10 hours for the car to sink so low, but once up it runs beautifully. The air compressor is not running extensively and I only hear it when I start up the car in the morning.
Please help!
To remove this ad, register today or login if you already are registered!
talha1210 is offline   Reply With Quote
Old 04-10-2011, 07:33 AM   #2
Drives: Mercedes
pull the hood release and leave the hood unlatched the night before. youll do a test the next morning and need the hood unlatched
the next morning when its low, open the hood and spray soapy water on the front shock towers (black area with hose coming out of center) using a spray bottle.
watch the soapy strut towers closely, as you get someone else to then unlock and start the car...if you notice bubbles as the car rises, you have a leak at the top of the shock towers (common issue and there is a seal kit).
if you dont see bubbles you have a leak but its elsewhere such as the bottom of the struts or maybe in a line
tusabes is offline   Reply With Quote
Old 05-06-2011, 12:08 AM   #3
Drives: 2000 S500
It was actually a leak with the valves on top of the compressor. My MB mechanic changed the valves and now my ride sits up like it should.
Old 05-06-2011, 08:43 PM   #4
Drives: Mercedes
thanks for updating, how much did it cost to fix?
Old 05-08-2011, 02:27 PM   #5
Drives: 2000 S500
The valve is $300 from any MB dealership. My mechanic charged $200 to put it in. But he did try initially to put a seal on it but it didn't work so we ended up replacing the whole valve.
My MBechanic has had a bunch of these so he had an idea on what he was doing. The way he found the leak was that they put some sort of colored gas into the air line and then looked for the leak.
I have heard that the leak may also be in the compressor and a new compressor woul be needed. They're about $300 on eBay. Good luck!
Old 05-09-2011, 07:35 PM   #6
Skylaw's Avatar
Drives: 2005 S500 4-Matic, 1978 450SL
Quote:
The valves you describe are commonly called the "valve block," for the convenience of other members who may have this problem. Thanks for closing the loop.
__________________
Warren
2005 S500 4-Matic with
Gateway 500 iPod integration
1978 450SL restoration project
Formerly: 2000 S500 with
Ice>Link Plus iPod integration,
MikBox, and Upgraded voice control
Skylaw is offline   Reply With Quote
Tags
2000, 500, airmatic, benz, car, class, front, location, low, lower, mercedes, mot, s500, sitting, valve
Search this Thread:
Advanced Search
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Copyright © 2001-2012 InternetBrands, Inc. / MBWorld.org. All Rights Reserved.
Everyone's Personal Details
SEO by vBSEO 3.5.2
