Sign in using an external account
| S-Class (W220) 1999-2006: S 320 CDI, S 320, S430, S 500, S 600
Sponsored by : My Mercedes Parts ![]() |
LinkBack | Thread Tools | Search this Thread | Rate Thread | Display Modes |
#1 | ||
Drives: 2000 S320 Dark Blue
W220 S320 2000 yr. Coolant visit Workshop! Please help!!
#2 |
W320 Coolant - Visit Workshop
I had a similar thing with my S320 Cdi W220. Check to see if the electric coolant fan is actually working. This is in front of the radiator in its own frame. It is a common problem. It should always be running when the air con is switched on, and runs at varied speeds depending on actual coolant temperature. Not a cheap part at circa £500 but you can fit it yourself with a little patience and gentle manoeuvring past the air con pipes. No need to drain anything, takes about an hour once you get the front under tray off. Good luck!
| Tags |
| 2000, 2006, 320, add, benz, check, coolant, mb, mercedes, mercedez, s430, s500, visit, w220, workshop |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Display Modes | Rate This Thread |
