Sign in using an external account
| S-Class (W220) 1999-2006: S 320 CDI, S 320, S430, S 500, S 600
Sponsored by : My Mercedes Parts ![]() |
LinkBack | Thread Tools | Search this Thread |
Rating:
Display Modes |
#1 | ||
Drives: MB 2003 S600. Volvo 2003 XC70.
#2 |
STOP: I'll try to follow MB standard procedure and stick with MB maintenance and repair specification.
But I can't guarantee all operation are MB standard plus no post is by any means official. There is no guaranteed everyone can get the same result by following my description. Please take your own risk and always use your own judgement in case you want to hands on. Post #2 is an Index for all the maintenance and repair tasks. - Maintenance defined as an item that isn't function impacted yet; - Repair defined as an item that already impact certain function or operation; Each task/item will be described by using: - Item number: Mnnn for Maintenance tasks; Rnnn for Repair tasks; Innn for information; - Observed Date: Date that an issue or problem has been observed; - Related Post: In which post under this thread this task/item will be addressed with details; - Status: Status of this item/task, whether it is Pending, Working, Done or fixed; - Cost: approximate cost to apply the maintenance or fix the issue - Description: item/task short description Vehicle information: Model: MB 2003 S600, W220.176 Engine: Twin Turbo V12, M275.950 Transmission: 5 Speed, 722.649 Options: Sport pkg, keyless go, heated steering, power close trunk. Here is the list for all tasks will be covered by this thread. Item# _Date__ _P# _Status Cost(CAD) Description R001 20111230 027 Fixed__ _350_____Engine Check with Misfire stored for #4, #8, #9. R002 20111230 000 Pending _________Engine Check for Charge air temperature is too high R003 20111230 059 Fixed__ _700_____Rust and bubbles on FR, RL & RR fenders. Left rear door frame also affected R004 20111230 003 Fixed__ ___0_____C/S Driving mode not working, ESM(Electronic Selector Module) interrupted R005 20111230 000 Fixed__ ___0_____Driver side mirror heater has Short circuit or open circuit R006 20111230 000 Pending _________HSW(Heated steering wheel) Control Unit undervoltage R007 20111230 000 Fixed__ __12_____Wheel Center Cap broken R008 20120109 006 Pending _________Sun Visor mirror frame broken R009 20120114 004 Fixed__ __50_____Ventilation Hose broken cause oil leaking on front top of Engine R010 20120210 036 Fixed__ __10_____Transmission shift rough when cold R011 20120114 053 Fixed__ __10_____Front right marker damage and parking sensor misaligned R012 20111230 057 Fixed__ __20_____Brown marks left on all 4 fenders' painting R013 20120519 089 Fixed__ __19_____Passenger Low Beam Bulb Failure R014 20120717 094 Fixed__ ___0_____CD Cartridge stuck in the 6 CD Changer R015 20130118 151 Fixed__ __60_____Front heater is not hot enough when cold outside, bad circulation pump M001 20111230 000 Pending _________Diver side ESA(Electric Seat Adjustment) No normalizing of backrest adjustment. M002 20111230 007 Fixed__ ___0_____Sun Roof not normalized reported by OCP(Overhead control panel) M003 20120109 018 Done__ _300_____Transmission fluid, pan gasket & Electric plug replace due to under pan leaking M004 20120109 000 Fixed__ 270 (Ind*) Front left lower Ball Joint has little play, replace with OEM part (Lemforeder) M005 20120109 000 Done__ _________Left Exhaust pipe bend forward, shorter than right side M006 20120109 000 Pending _________Front Pads worn, around 4 mm M007 20120109 000 Pending _________Rear Rotors rust M008 20120113 000 Done__ __62_____Front wiper blade deteriorated M009 20120113 016 Done__ 1400_____Need winter tires/rims to improve winter driving ability M010 20120113 019 Done__ _100_____Engine oil & filter replace M012 20120114 074 Done__ _250_____ABC suspension hydraulic fluid & filter replace M013 20120114 087 Done__ _100_____Differential oil replace M014 20120114 154 Done__ __50_____Coolant replace M015 20120114 032 Done__ __60_____Air Filter replace and Trottle Body clean up, MAF maybe M016 20120114 000 Done__ __30_____Steering fluid replace M017 20120114 035 Done__ _300_____Spark Plug replace M018 20120210 038 Done__ ___0_____Tranmission Control Module clean up, box full of oil M019 20120225 088 Done__ _175_____Fuel filter replace M020 20120420 081 Done__ __60_____ABC Valve Block clean up M021 20120509 086 Done__ __20_____Cabin/Dust Filter replace I001 20111230 043 NoIssue _________Need push gas to back up I002 20111230 149 NoIssue _________Car won't start when SmartKey turned I003 20120210 150 NoIssue _________Small amount Metal/Aluminium flake/shaving/swarf in Transmission filter I004 20120930 100 NoIssue _________Procedure/action list when ABC has issue or ABC message show up I005 20121222 112 Member _________ABC Pulsation Damper exploded and fix I006 20130131 146 NoIssue _________Check coolant level and top off (main circuit) I007 20130210 155 NoIssue _________Navigation volume very low, can't hear the instructions Ind*, Task carried by Independent mechanic. By the way, you may want to open a new thread if any issue not listed here but need to be discussed. And we could keep this tread focus on it's own purpose. Last edited by Glyn M Ruck; 02-21-2013 at 04:51 PM. |
#3 |
R004 C/S Driving mode not working.
Issue description:
When push the C/S switch on Gear Shifter/Electronic Selector panel the driving mode won't change from Comfortable to Sport. And the selector panel won't light up either. Issue reported as a fault in Star scan: ESM - Electronic selector module P1911 The link between control module N15/5 (Electronic selector lever module (ESM [EWM])) and the shift gate illumination is interrupted. Cause: Electric connector to the Selector panel loose. Repair: Remove Shift Knob (picture 1) Remove Selector panel then reconnect Electric connector (yellow one on picture 2). Reinstall Selector panel and Shift Knob. If possible, clear fault memory and retest ESM. Result: Drive mode can be switched between Comfrotable and Sport. Selector panel lights up after engine start. No error code reported after the fix. Last edited by haoz129; 01-22-2012 at 11:42 PM. |
#4 |
R009 Ventilation Hose broken.
Issue description:
Oil mess on top of engine around left front side. Cause: Valve on Ventilation Hose (Press. Reg. Valve to Charge Air Dist. Line) broken. Part No. for this hose/valve assembly: A 275 010 05 82 Repair: Replace hose/valve assembly. Result: No oil leak from the valve. Last edited by haoz129; 04-06-2012 at 02:32 PM. |
#5 | |
Quote:
Good luck with your new baby. Keep up the good work. Johan
__________________
2003 S55 AMG |
#6 |
R008 Sun Visor mirror frame broken
No big issue.
If come accross a good used one that's the solution. |
#7 |
M002 Sun Roof not normalized.
- OCP - Overhead control panel B1066 SR (Sun Roof) is not normalized Cause: SR was not normalized. For example after replace battery. Adjust: Normalize SR Press SR switch upword to raise SR at the rear. Wait until the SR is raised and hold the switch for approximately one second. Result: No error code reported after the normalization. |
#8 |
SPONSOR
This poor S600 has no idea what it's gotten itself into.
![]() Bruce |
#9 |
Drives: 2003 S500, 03 C240, 03 E320, 03 tahoe
these are expensive
#10 | |
star service dvd
Quote:
#11 | |
Drives: opposite-lock...
Quote:
design flaw apparently - stress points or something least now I know to be careful! keep hammering away @ them thar codes! UCANDOIT!!!
__________________
-Paul... CT '01 ///M5 '87 930 '07 GL450 - what's her face ![]() European Car Magazine: E500 Limited //SFest Previous: '05 S600 Sport - 495rwhp / 612rwtq '96 993 C2 cab - commuter '58 TR3A - Godspeed '01 //S8 '02 ML320 3rd row '95 //S6 6spd '98 ML320 '84 4000q '87 190E 2.3-16 '93 300E 2.8 '91 300E '88 ///M5 '80 242GT '76 VW Westfalia |
#12 | |
Quote:
Yes, I'm a computer engineer and they call us dinosaur. We work on huge computer system which can be used forecast weather. Sure, will keep doing and sharing. Best regards. Howard |
#13 |
#14 | |
Quote:
I got the DVD you mentioned before. Very informative. It'll guide me through every tasks. Yes, I used them kept sun shade as well in my Volvo. BTW, I just got a quote of a used driver side Sun Visor for $120 with shipping. Will share the result soon. Best regards. Howard |
#15 | |
Quote:
.I agree with you, kind of flaw design, pretty weak and fragile after years. I think it's less improtant for us then for a lady driver. They will use it more often, I saw woman making up during driving, .But anyway, no car is perfect, just get use to it. Best regards. Howard |
#16 |
M009 Need winter tires/rims.
Winter tires/rims are must have to handle Canadian winter.
And winter tires make huge difference than all season and summer tires. How much difference, if you don't try you can never tell. Got 4 AMG original rims, used dial indicator to check straight variation (unit: measured by 1/1000 inches): ___InSide_OutSide(Spoke side) LF: __18____04 RF: __38____13 LR: __14____05 RR: __30____08 Industrial standard for alloy rims, radial runout should be less than 30x1/1000 inches. Make sure all rims is within specification can help get good tire balance. Seems I need to get a better one for RF. Rims need to be refinished due to previous curb rash. Last edited by haoz129; 01-23-2012 at 08:02 PM. |
#17 |
R001 Engine Check with Misfire stored.
Will try replace spark plug first.
Parts: - Spark plug (A 004 159 14 03), $268: I'm using OEM Bosch FR7KPP33U x24, factory gapped; - Spark plug gasket (A 000 159 00 80), $10; - Anti seize; - Dielectric grease; Last edited by haoz129; 01-27-2012 at 11:47 AM. |
#18 |
M003 Transmission fluid, pan gasket & Electric plug replace
Parts:
- Transmission fluid (A 001 989 68 03 13), 10L for $218: MB ATF 134, sheet 236.14; - Transmission filter (A 140 277 00 95), $21; - Transmission pan gasket (A 140 271 00 80), $23; - Transmission plug gasket (A 140 271 00 60); - Torque converter plug gasket (N 007603 010100); - Filler cap lock pin (A 140 991 00 55); - Electric plug (Pilot bushing, A 203 540 02 53); Last edited by haoz129; 01-27-2012 at 11:50 AM. |
#19 |
M010 Engine oil & filter replace
Parts:
- Engine oil filter kit; - Drain plug gasket; - Oil filler cap gaskt; - Engine oil: Mobil 1 Synthetic 0W-40; |
#20 |
SPONSOR
This guy's gonna get to 500 posts in a week, it took me like three years.
Bruce |
#21 |
Drives: Mercedes
Howard I love this thread!! Very detailed. Can you include parts prices and your labor time on each project too ?
#22 |
#23 |
Wow awesome thread I'm Lot's of people will use your help on here.
#24 |
Drives: S600
Howard,
You are a gentleman and a scholar. As I said in your previous thread, you are one cool dude. The first thread you ever started became epic and your second is an instant classic. MB owners will be using this thread for years. UDAMAN Howard!! Keith |
#25 |
Drives: 2000 S430, 97 850 T5
Sticky this! I'll be referring to this for a decade or two...
__________________
Ordinary S-Class isn't enough? Last edited by Vmaxx; 02-06-2012 at 02:23 PM. Reason: / |
| Tags |
| 2003, amg, coil, cost, engines, forum, maintenance, mb, oil, pack, repair, s600, service, transmission, w220, weight |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Display Modes | Rate This Thread |
