Sign in using an external account
| S-Class (W220) 1999-2006: S 320 CDI, S 320, S430, S 500, S 600
Sponsored by : My Mercedes Parts ![]() |
LinkBack | Thread Tools | Search this Thread | Rate Thread | Display Modes |
#1 | ||
Is It A Coil Pack ????
#2 |
Also, has everyone seen the $41. individual coils? See them at: http://www.amazon.com/96-02-Mercedes-Ignition-0221504001-0001587203/dp/B003TI640A%3FSubscriptionId%3DAKIAJAOOGQTQGLTE7LIA %26tag%3Dfb4amz08-20%26linkCode%3Dxm2%26camp%3D2025%26creative%3D165 953%26creativeASIN%3DB003TI640A
#3 |
ALSO PLEASE.....
What is the name / description / part number of the "Box" at the front of the Ignition Pack please? I may want to buy it seperately. ALSO, What is the name / description / part number of the rubber boots that go over the plugs and attach to the bottom of the coils please? LASTLY, What are the Brand(s) and number(s) of Spark plugs that will fit an 2001 S600 NA please? Thank you. |
#4 |
Drives: MB 2003 S600. Volvo 2003 XC70.
Hi GrandMa.
I'd think it's the Coil Pack. If part of the coils are not stable car may still be drivable. MB use 2 coils/sparks per cylinder. Is the issue surfaces when car cold ? The individual coil in Amazon you quoted is not for W220 S600. W220 S600 only use Coil Packs. One Coil Pack for each bank. Each Coil Pack intergrate 12 coils which assembled as one unit. Althoug I fixed those coil packs by soldering individual coil I didn't see anywhere selling the coil. Regular owner can't use the individual coil even sold somewhere. I guess the box you mentioned is part of the Coil Packs which can't be serparated either. The rubber boot is called Spark Plug Gasket, A 000 159 00 80. Thanks. Howard |
#5 |
01 S600 Coil Packs
Hello Howard:
Thanks for the reply. Since my original message, I have disconnected the driver's side coil pack plug. NO CHANGE ! I was astonished when the car Idled very smoothly, ran, shifted and would be unoticed by a "little old lady". This in comparison to when the issue first started (a week ago) the car shook, stalled and had a very hard time making it to Thruway speed. (see the gasoline issue below) Now, shaking or stalling or inability to get ANY acceleration, is no longer an issue. The car idles very smoothly and accelerates like a 6 cylinder... on just the passenger bank! An unknowing person would not notice anything wrong with the car.... Very hard for me to comprehend. The one thing which crossed my mind was BAD GAS. I filled the car up shortly before the issues started. It was near empty. After the problems started and the car had 2/3 tank left, I filled up the 1/3 from a different Sunoco station, the improvement began. Obviously, I am looking for a way to dodge the $1200 coil pack. I was going to run the tank all the way down and re-fill with "Sun 260". My thought being that, as the Coil Pack actually (so I have read) responds to the cylinder temperature / high octane gas and adjusts the spark and timing accordingly, maybe a full tank of high octane will resolve the issue. Also, would the "Ecconomy/ Thruway Mode" being stuck "ON" shut down the one bank (My codes are 7,8,9,10,11,12 misfiring)? Are the coil packs FUSED or have a "circuit breaker cube"? Would bad O2 sensors (2 per bank/ both of them) shut down the Coil Pack? Bad Air Mass Sensor? Other ideas please? Thanks for any assistance. Tom Last edited by TheGrandmaDee; 05-04-2012 at 11:22 AM. |
#6 | |
Quote:
Are you saying the beast idles smoothly without left bank ? That's astonishing indeed. What a nice engine. Yeah, you still got 6 cylinders which is more than most of the cars have, just don't race, ok .I don't have idea about "Ecconomy/ Thruway Mode" as I have a 03. But I don't think misfire msg will be triggered when ECU turned a bank off. For further investigation, I'd like to take it to a shop to clean the massages. Put left bank back on, run a while to see whether the misfire is still there. As entire left bank has misfire it could be also traced to the Transformer which is a black box on top center of the engine supplying electricity to both Coil Packs. Anyway you'd better have someone read the fault memory. A general reader can't handle it. Need a MB Star/SDS equivalent. Without all fault codes reflecting the entire picture our guess could cost you more. Thanks. Howard Last edited by haoz129; 05-04-2012 at 11:38 AM. |
#7 |
hey crazy grandma..
when last time your beast got a tune up? spark plugs change? try that first...check engine lite is on...Codes read "misfires" in 7, 8, 9 ,10 ,11, 12...usually if it set code for that cylinder meaning those cylinder are misfired...need to be correct...its common failure coil packs....its hard to tell if those coil you disconnected make any changes at idle...because its a V12... i would try to change spark plugs first...clear the code and see if the code come back.. if it does come back later, then you have to replace the coil packs.. good luck |
#8 |
Drives: Mercedes
a v12 is like two inline 6 cylinder engines, so yes it would still be very smooth even with one whole bank not firing
| Tags |
| 2003, amazoncoil, coil, coils, mercedes, needed, pack, packs, plug, plugs, replacement, s600, spark, tight, tools, v12, w220 |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Display Modes | Rate This Thread |
