hood adjustment
Old 04-12-2013, 05:36 AM
HasanBalkaya's Avatar
2001 Mercedes S 320
Exclamation hood adjustment
Hello!
I'm a new member forum
My problem As can be seen in the picture
is not equal to the right and left .
How can I do equal
''2001 S320 Short ''
Thanks to everyone !!!
Old 04-12-2013, 09:10 AM
mrbobby's Avatar
2003 S500 4Matic (SOLD) + 2004 S55 (SOLD) 2005 CLK 500 Cabriolet 2008 S 450
From the photo it would seem as if the hood to fenders is just about perfect. If anything the bumper cover needs to come up on the driver's side. I have 2 W220 vehicles and what I am seeing is not unusual. Most people won't notice the difference, after all it is a 13 year old vehicle.
Old 04-12-2013, 11:32 AM
vmystikilv's Avatar
Range Rover
That would drive me insane. I hate it when the outside pieces don't line up. From the look of it the rest of the car is lined up so it hard to tell what piece is off from alignment. its either the bumper or the hood though. This may not be a simple fix. Is the bumper warped ?
Old 04-12-2013, 12:27 PM
2001 Mercedes S 320
bumper is not distorted !
fender equal distances !
Is it possible to tune the hood hinges?
Do you have another set screw inside?
defective left front AIRMATIC !!!
Could this be the reason?
THX
Old 04-12-2013, 06:08 PM
wallyp's Avatar
2003 S500 2007 GL450
Can't really tell from the photo, but it looks as if the bumper is low on the passenger side, and the hood is a little high on the same side. Look at the space between the bumper and the bottom of the headlights. The bumper needs to be raised slightly. May be bent brackets or poor adjustment - only inspection will tell.
There are two hood stops, one on each side. Look for a round disk with a point in the center just behind the headlamps. These screw up and down to act as stops or supports for the hood. You may also need to adjust the hood latch slightly.
Old 04-12-2013, 10:22 PM
vader14's Avatar
2000 S500/2001 S55 (sold)/2005 S55 AMG
If your referring to the gap between the bumper & the hood. All w220's 99-02 have that same gap. I have a 2000 S500 & had a 2001 S55. Both have that gap.
If you take a look at 2003's & up, the hoods are different. The hood on the newer ones are open at the bottom. The grill is also a little longer which closes out that gap.
Hope that helps.
Old 04-12-2013, 10:34 PM
trombone's Avatar
2002 S430
The bumper is hanging low everywhere on the right side, there are uneven gaps:
under the grill, the headlights and on the side where it meets the fender.
The hood looks fine.
Old 04-13-2013, 03:25 AM
2001 Mercedes S 320
you show with photography ?
Old 04-15-2013, 05:26 AM
2001 Mercedes S 320
apparently do not have one
Quick Reply: hood adjustment
