Horrible Sound from the Center Console!
'05 S430 4MATIC Sport, 2009 GT Zaskar MTB
Every time I'm making turn or there is lateral movement and you are being shifted side to side in the drivers seat, the bottom portion of the seat is touching/pressing against the center console, which is making a horrible sticking sound. I have to say probably the most annoying sound I have ever heard in the interior. Looks like the console covering is attached with glue of some kind and over the time it lost it's full strength, but still remains sticky. I can also locate the area, and push it with a finger to recreate the sound. I'm going to have to remove the entire console and come up with repair solution.
Does any of you experienced anything similar?
96 and 08 911 turbos
I don't quite understand what is happening here.
The seat touches the center console and causes a "sticking sound"?
There is glue on the outside of the console? from where?
pics of the area may help.
No not outside. Inside between the plastic structure of the console and the actual outside covering.
Here is a picture.
Here is a picture.
1 Post
2003 S 500 4 MATIC , 2001 S 430 , 2003 ML 500
There should be a sort of fabric covered spacer if you will that slides between the seat & the center consoule do you have those type of inserts ? I took both of mine out and I am hearing a noise that I cant figure it out maybe its the same thing
When you push the seat all the way back do you notice any marks where the seat may have been rubbing against the console?
No. Everything is original. I did not remove anything. There are no visible scratches. This sounds occurs inside the center console. Between the plastic structure and the top covering layer.
