2002 S420 Trunk opens only half way and shuts
2002 S430 Trunk opens only half way and shuts
I recently purchased 2002 S430 with very low miles on it and having problem with the trunk opening only half way and closing it by itself after 2 minutes or so and sometimes I can't close it by pressing the red button on the trunk lid. I don't know whether the trunk hydrolics struts are bad and need to be replaced or not. Can someone help me please?
As for as the opening half way you can check the trunk limiter in the vehicle settings that show up in the little screen under the speedometer. These settings are controlled from the steering wheel. Make sure the limiter is set to off.
Assuming you can resolve that problem and can get the trunk to go up all the way and it doesn't stay in that position then you could possibly have a trunk
strut problem.
strut problem.
strut problem.
strut problem.
Thanks for the post. I still can't find the settings for limiter in speedometer screen.
Hold the button down on the driver's door that opens the trunk for about 10 seconds. (Don't open the trunk with that button just hold it down for now. Now open the trunk and see if that resets to the manufacturer's setting and open it all the way.
W220
UOTE=jn02s430;6088866]I
Open trunk and check your hydraulic pump it's next battery on the right side lift the foam top of and lift out pump. It has a see tegu plastic cover that can be removed for filling purposes. Check and make sure you use correct zf fluid. Do not use transmission fluid. You can unscrew all the hydraulic lines and then put it on bench. Pour fluid directly onto pump let it drain into small orfices Untill full. Then fill plastic cup all the way and quickly flip pump over setting it on the filler cup. Some fluid will spill but that's okay. Reinstall pump and you should have good working trunk. Good luck.
recently purchased 2002 S430 with very low miles on it and having problem with the trunk opening only half way and closing it by itself after 2 minutes or so and sometimes I can't close it by pressing the red button on the trunk lid. I don't know whether the trunk hydrolics struts are bad and need to be replaced or not. Can someone help me please?[/QUOTE]
Thank you so much John. My problem is resolved with your suggestion. I turned on the engine and held down the trunk open button on the door for 10 seconds and the trunk opens all the way up now.
2009 E350 4M Avantgarde;mistress 2002 S600; wife 2014 C300 4M
trunk hydraulics
if you search my threads here and on Benzworld, you will find the instructions on how to check and refill the reservoir. You do not need to disconnect any hoses, you can do it right in the trunk.
Observe my safety warning!
I have photos for all steps with my posting.
Good luck!
Good luck!
Can you tell me what type of fluid did you use to fill up the reservoir and where is your post listed under. I tried serching with "how to check and refill the reservoir" but didn't find yours.
When you say "small orifices", are these the holes from the two hydraulic lines that should be filled?
[/QUOTE]
