Leak from upper radiator , still leaks after replacement
Old 07-17-2014, 11:01 AM
vmystikilv's Avatar
Range Rover
So last month my upper radiator hose split, I bought a new one from the dealer , replaced it, and all was fine. Now, its leaking again, but , it is extremely small, super small. If I were to park it there would be a dime size drop on the ground and that's it after . I thought I had a bad hose but the hose checks out fine. I cant tell were the leak is coming from this time, any ideas, hose has been changed. Is there a way to tighten?
Old 07-17-2014, 12:45 PM
drewk88's Avatar
2004 S600 Twin Turbo V12
There's an o-ring in there, might that be the problem?
Old 07-17-2014, 01:18 PM
vmystikilv's Avatar
Range Rover
the o ring Is part of the hose, since it was under warranty( had just bought it, I went and got a new hose, same problem.
Old 07-21-2014, 07:56 PM
SpamNRice's Avatar
250c, c43, s500
where you the one who replaced the hose? Maybe there is a hairline crack on the radiator itself
Old 07-22-2014, 12:14 AM
vmystikilv's Avatar
Range Rover
well apparently it stopped leaking so im not even worried about it anymore. go figure. been dry as a bone for the last two days.
Quick Reply: Leak from upper radiator , still leaks after replacement
