coolant shooting out of windshield reservior
Old 07-21-2014, 12:33 AM
adrenaline12055's Avatar
W220
hey guys, after my car reaches operating temperature it mixes coolant into my windsheild washer reservior. From there it starts leaking and my check coolant light comes on. I cant seem to figure it out! help! thanks!!!
Old 07-21-2014, 06:36 AM
tusabes's Avatar
Mercedes
Your windshield washer reservoir is heated
Check for coolant leaks in the washer heating system
Old 07-21-2014, 12:44 PM
wallyp's Avatar
2003 S500 2007 GL450
Remove the larger plastic cap from the washer reservoir. Remove the washer fluid (which will be contaminated with coolant) and safely discard. You can remove most of the fluid by pulling the pump from the tank on the lower front side.
The two metal lines entering the tank are the coolant loop that heats the washer fluid. There will be a leak somewhere in that coolant loop. Remove and repair the loop, or bypass it outside of the tank. Thoroughly clean the tank to remove all traces of coolant - it will make a mess on the windshield otherwise.
Old 07-21-2014, 03:54 PM
Former Vendor of MBWorld
ECSTuning's Avatar
2012 SLS AMG
adrenaline12055,
Most likely, the Washer Fluid Reservoir Heating Element has failed, allowing coolant to mix with the washer fluid.
The Washer Fluid Reservoir Heating Element is still available from Mercedes-Benz, and we offer it on our website. You can get to it by clicking HERE.
Old 07-21-2014, 10:41 PM
tusabes's Avatar
Mercedes
Your links don't work ECS
Old 07-22-2014, 07:47 AM
ECSTuning's Avatar
2012 SLS AMG
tusabes,
I'm not having any trouble with them. I tried them in different browsers, too.
The links are all correct and complete.
If you are trying to get to the Washer Fluid Reservoir Heating Element (MB Part Number 2208300061) click HERE.
All of the above links work, too. I checked them in Preview Post before I submitted.
Old 01-16-2015, 10:45 PM
hamidmemar's Avatar
S430, C320
Heater element is stuck
My S430 has the same problem. I tried to remove the heater loop, but it is blocked by something inside the reservoir. Is the heater loop connected to something inside the reservoir?
Old 01-17-2015, 03:20 PM
cybertronicify's Avatar
2003 S430, 2014 E350
Mercedes uses the engine coolant to heat the windshield wiper fluid. It does so by running the hot coolant loop inside the washer fluid tank, this making the washer fluid hot so it can be used to de-ice the windshield if needed. Do not use the wipers because the hose line is not made to carry coolant and can degrade the material. And coolant is super hard on the clear coat over your paint. You can bypass the hose of you don't live in anywhere too cold.
Quick Reply: coolant shooting out of windshield reservior
