2001 S430 Airmatic Noise
Mercedes S430 & Suzuki SV650
Hello:
This S430 has an intermittent noise that occurs when driving. It also happens when the Airmatic button is pressed on the dashboard. Once the button is pressed, a few seconds later it sounds as if the pump is running, but it doesn't sound normal. It's very loud.
I ordered a new relay and all fuses are fine. Checked the tops of the air struts and they don't appear to have cracks in them.
I don't know if the pump is about to blow or what. The car is not rubbing against the tires or anything like that; it also is not unusually low. I don't believe any of the struts are bad, I just feel like it has something to do with the pump or the air connection somewhere along the way.
I can take a video of the exact problem in the morning to help further diagnose the issue.
Thank You & Have A Good Evening.
rwest (10-13-2019)
