Can removing/replacing fuses cause warning lights to come on?
2000 S500
I did some work on my 2000 S500 causing me to have to remove the radiator and fan shroud, and when I got it back together the radio worked, but I didn't get any audio through the speakers. I read on a post on one of the forums where removing the fuse for the radio would and leaving it out for two minutes and then replacing it would "reset" the audio system. While I was at it I thought I'd check all the fuses I could find so I pulled them all, checked them, and then replaced then. I don't know exactly which one, if any did it, but I now have tunes in the car.
However, ever since then, just about every warning on the drivers information center comes on and the air suspension won't pump up. Is it possible my removing/replacing the fuses caused this? Can all this be reset and if so, how? For that matter, how do I reset the warnings on the drivers information center?
Thanks in advance.
Wendell
Thanks in advance.
Wendell
Never heard of this kind of problem before. However, you can disconnect the battery for about 1/2 hour. After reconnecting the battery make sure you go through all of the resync processes which are outlined in the encyclopedia.
