Water in my cabin
2002 S-430
Water in my cabin
The rainy season known as winter just started where I live and I just noticed that I'm getting a ton of water coming into my cabin on the passenger side through the air vent under the glove box. Is it just pouring into my car through the hood or is something else wrong?
If you're getting water inside the passenger footwell stop immediately
Open the hood and clear the drain tube under the plastic grille thats right under passenger side windshield , its at the very bottom so you'll need a chopstick or long skinny device to poke it open
Once you clear the drain hole the water should drain under your car instead of into your car
You must also pull up your passenger carpet and soak up all the water , if you don't it will flow straight to your rear SAM and fry all your electronics
See here
See here
2002 S-430
I found the drain and everything other than my passenger mat appears to be dry. Could this have been causing the intermittent fault in my left brake light too?
Thanks guys for everything.
Yes it can result in numerous electrical faults
Don't just check your floor mats , you need to pull up the passenger side carpeting , it pulls out easily from the top under the dash
There is a recess channel under the carpet where wires run and that's where the leaking water flows and does Damage. Your mat may be dry on top but under the carpet it can be full of water
Need help with my Mercedes S43
Only in the morning when I start car sometimes ignition won't turn must Play with it....and then climate control is blinking radio goes on and off ABS light comes on Bas and esp and aromatic come on The dashboard....once the car warms up everything is okay.....went to a mechanic there was water in under hood in the water In the drainThe guy unclogged it now what please help thank you so much
Pull up the passenger side carpet from under the dash to expose the metal car floor
If it's wet in there and you have comprehensive coverage on your auto insurance , file a claim . Comprehensive covers water damage
If you have liability only then you'll need to remove the seats, dry everything and start replacing electronic modules from the rear SAM forward
