door lock will not open with the key fobs
2003 Mercedes-Benz S500
I have a w220 s500 and have been experiencing issues with the door/truck locks. It only happens when the car sits for an extended period of time (3+ hrs). It won't open with either of the fobs til I start the car and run it for 15 minutes or so then it will work again. I have checked the batteries in the car and in both fobs. Anyone have any ideas?
I'm still thinking the battery. These batteries might show that they are OK but still doesn't have enough power to run everything. I had one go out on me that was about 9 years old. Turned out to be a dead cell in the battery even thought it was testing OK.
If your battery is only 7 months old then it should definitely be under warranty.
I'm thinking there's a leak in the pneumatic air lines. It's been pressure tested however the problem only occurs when the car sits for a few hours.
The RF amplifier tested good, the charging system is good, fuse are all good , all the codes were clear, I'm stumped!
Same issue with my 2001 CL w215. If I sync one key by putting it in the ignition my second key will start working. For some reason the car's memory doesn't recognize the key fobs after a couple hours.
