Mysterious fuse
W212 E500 4Matic, W220 S500L
Mysterious fuse
My car is a 1999 S500L.
In the past I have had an electrical problem that draws power, and the battery is empty over night. It draws approximately 1.3 A. I think I have found the error. When I removed fuse # 60 in the fuse box under the rear seat, the power consumption is normal.
But I can not find fuse # 60 in the fuse chart. What is # 60 connected to?
Anyone knows?
I have removed the fuse, and I don't think that I have lost any functions.
Thanks for any advice.
Jawo
Anyone knows?
Jawo
2002 S430
Fuse charts are different depending on years and models.
On my chart (A 000545 16 00) f60 is not listed for any application.
On the map it does have a vacant space in the box, Amperage unspecified, and I have no fuse at the indicated place.
If you found you have everything operational without it, remove it from the fuse box and keep it in your curios. Especially if your chart does not list it either.
main switches and knobs are all working.
I know I can dismantle the fuse box and follow the wires from the fuse # 60, but it is too much work. It is strange that those who have connected the fuse has not marked it with what it is connected to.it is 25A fuse
On the 2005 models, the fuse #60 is connected to Antenna booster, and to Electronic toll collection.
My car has neither
Jawo
It is not unusual for an owner to feel that there should just not be an empty fuse slot, and so fill it, with no regard for actual function. Sounds as if your PO (Previous Owner) was one of those.
Yes, it may be a joker with recreational problems who owned the car before me
Anyone knows?
Jawo
Anyone knows?
Jawo
I must find a way to prevent water to get into the switch.
Jawo
