Now is navigation!
Old 03-28-2015, 03:11 PM
Neo0019's Avatar
2002 430S
Now is navigation!
I put in Naviagation CD 6 for PA. ANd all it saids it's initialaizing navigation please pay attention and stuff like that. It stays there for ever I have the antenna on top of the car that for some reason is very lose I have check under the glove compartment and wasn't able to locate the antena. Even on the dash when the car is on it says navi off..
Any help will be appreciated.
Old 03-29-2015, 12:17 AM
Neo0019's Avatar
2002 430S
Any body?? I have look everywhere for an answer..
Old 03-29-2015, 11:41 AM
ibeforreal's Avatar
2003 S500 - Toyota Corolla (in the rain)
Read through this thread: http://www.benzworld.org/forums/audi...ites-help.html
Old 03-29-2015, 12:34 PM
Neo0019's Avatar
2002 430S
Thank you so much
Old 03-29-2015, 01:45 PM
Neo0019's Avatar
2002 430S
I read. I check my connection behind the passenger in the trunk and nothing at all everything looks brand new no water marks or anything I check under the hood looking for fuses but nothing all of the fuses are ok, can some please tell me where the navigation fuse is located?
Old 03-29-2015, 05:20 PM
ibeforreal's Avatar
The fuse box for the command and instrument cluster is located on the right side of the front dash. If you open the passenger side door you will see the cover there. You will need a small pocket screwdriver to pry that cover off. It looks like a triangular shaped thing with a an air vent.
Old 03-29-2015, 08:34 PM
Neo0019's Avatar
2002 430S
Here is a chart of every fuse in the car. I haven't being able to see the one you are talking about. My antenna is very very lose but in good condition. I just don't undertand why I put the disk in and nothing happens even on the cluster it it reads navigation "off". Very puzzling.
Old 03-29-2015, 11:52 PM
ibeforreal's Avatar
Do you have an owner's manual? If so the manual will show where the fuse locations are. However, if your antenna is very very loose then it is probably a connection problem.
Old 03-30-2015, 06:19 AM
Neo0019's Avatar
2002 430S
Yes I have the owners manual, on my phone. The antenna is very very loose I'll buy some glue and re glue it back in place but as far serge wires that are a attach to it everything is perfect It puzzles me why it won't turn on. Radio and everything else works just fine I'll I've and update this after noon
Old 03-30-2015, 05:43 PM
Neo0019's Avatar
2002 430S
Two of the antenna cable have a bit of the protective rubber peal off just a bit I both of them
Old 04-03-2015, 09:07 PM
Neo0019's Avatar
2002 430S
Well I went to the dealer, and got it diagnosed it's the command unit that's damange. They quote me at 680 plus labor. I just order one from eBay for way less. Any advice on how to connect is it strait forward? Thanks.
Quick Reply: Now is navigation!
