S 430 SRS LIGHT IS ON IGNORE IT ? OR WHAT ?
Old 04-19-2015, 12:30 PM
S430LUCKDRAGON's Avatar
2003 S 500 4 MATIC , 2001 S 430 , 2003 ML 500
After owning the car 2 years SRS light is on now so im reading on line I tried cleaning the connectors with electrical cleaner but to no avail any suggestions ?
Old 04-20-2015, 12:36 AM
VMAX7's Avatar
2000 S430, 2000 S500 Both Brilliant Silver!
Ignore. Better yet, pull the bulb.
Old 04-20-2015, 12:45 AM
cybertronicify's Avatar
2003 S430, 2014 E350
The SRS light means you have an error in the restraint system. Making the car extremely dangerous. An airbag could deploy out of no where and cause an accident. Or even not protecting the passengers when an accident does happen. I would suggest you get it checked out with a STAR diag system.
Old 04-20-2015, 01:06 AM
ibeforreal's Avatar
2003 S500 - Toyota Corolla (in the rain)
It could possibly be the passenger seat SRS sensor. Does the light come on when someone is sitting in the passenger seat or does it stay off?
You can try raising the seat and looking at the wires to see if any of them are frayed or damaged. If you do find a frayed wire don't fool around with them unless you disconnect the battery for at least a 1/2 hour. Those AIRBAGS are no joke and can hold memory for quite a while.
Old 04-21-2015, 10:42 AM
Ok I will see what I can find thanks guys , by the way the light is just on all the time and blinks every so often
Old 04-21-2015, 04:06 PM
Ok well the SRS light is gone for now I sprayed some electrical cleaner on the wires leading into the module under the drivers side seat we will see if it comes back
Old 04-21-2015, 04:17 PM
mercy-me's Avatar
2012 E350 4Matic P2
The only way to truly know which component in the system has failed is to have the car scanned with an advanced scanner on the level of STAR/DAS. My guess is that the passenger seat sensor is bad as John suggested. That sensor is the most common cause of the SRS (Supplemental Restraint System) light to come on. Some have installed a seat occupant simulator to get the light to stay off permanently. My SRS light comes on when a passenger first sits in the passenger seat then goes off soon afterward. Sometimes the light will again illuminate when the passenger exits but will go off soon afterward. Eventually, I anticipate a repair job in the making.
My understanding is When the SRS light is illuminated on the dash, this means that the Airbag Control Unit sees an issue in the system and has disabled the system. This means that the airbags will not deploy in the event of an accident. I can not say for certain if this is 100% the case. Hopefully some learned member will correct me if my statement is wrong.
Good luck and post back your success story,
Bob
Old 04-21-2015, 06:19 PM
ibeforreal's Avatar
I don't know what type of vehicle inspection laws they have in CT but in most states if the SRS light is on during their scan the car will not pass inspection.
Old 04-21-2015, 06:53 PM
compaddict's Avatar
2016 S63, 2013 SL63
I knew that my seat sensor was bad because the passenger could jump up and down or wiggle to turn it off.
That being said, I replaced the sensor for safety reasons.
Old 04-21-2015, 09:34 PM
For right now the light is still off , I have a strong suspicion that it may have just been ashes accumulating near the wiring connector as i do smoke a lot in the car , my seats have the air cushioning and have not worked on drivers side since I bought the car , but after spraying electrical cleaner on the connectors there I heard it briefly shoot out some air , I would still like to know where that sensor is located as mercy me said I do for see a future replacement hope fully not but you never now if the light will come back on , I am still fascinated with these cars and it is an incredible learning experience and money pit and ibeforreal you are right it wont pass inspection like that with the SRS light on I am currently back in RI and just got a new two year inspection a few weeks ago , but it wouldn't pass in RI MA like this CT is no safety inspection cars just have to pass emissions go figure
Old 04-22-2015, 09:34 AM
wallyp's Avatar
2003 S500 2007 GL450
The sensor is a net-like device covering the passenger seat between the leather and the cushion. The seat has to be removed and disassembled to install the sensor.
Old 04-26-2015, 04:49 PM
The SRS light is still off its been what i want to say 5 days ? It doesnt evan come on when you first start the car any more i guess in my case it was just all the ashes got into the wiring harness but i will let you know again if it comes back thanks guys
Old 04-27-2015, 07:36 PM
framer's Avatar
2007 ml350
maybe the srs light bulb burned out
Old 04-27-2015, 10:49 PM
ibeforreal's Avatar
THose bulbs very rarely burn out.
Old 04-30-2015, 11:12 PM
Its not the bulb , i got a new scan tool that is just for MB its not star diagnosis but its damn good it is saying its a the SRS sensor on my drivers seat had been faulty at one time but like i say the light is still gone
Old 05-02-2015, 07:43 AM
tusabes's Avatar
Mercedes
What scan tool did you get and how much is it ?
Old 05-02-2015, 10:50 AM
icarsoft i980 it was about 149$ on e bay worked great on my 2001 s 430 but i might need to update the software because it wont link to my freinds 2006 e 350
Quick Reply: S 430 SRS LIGHT IS ON IGNORE IT ? OR WHAT ?
