Whar is the correct oil for w220 trunk soft close compressor?
I am sure Bavarian engineers don't think atf and hydraulic oil is the same. Does anybody know for a fact what the correct oil is to refill the little sealed for life reservoir on the tiny compressor in the trunk that operates the soft close, please?
Also, does the reservoir unscrew or how do you get in there. Is there a fill screw like with the SL convertible tops?
Best regards
Best regards
Are you talking about the soft close for the doors? The doors are controlled by a PSE pump and actuators. Are you referring to the unit that controls the trunk open/close?
I use Pentosin CHF 11. Some people use regular ATF but the Pentosin is much better and will last longer. It comes in the green can.
