Hissing AIR sound when I go over a Speed bump...
Hello everyone,
This is my first post.
I just noticed that when I drive over a speed bump, I can hear a hissing sound. It is not a constant sound, it sounds more like a bus with air brakes when a bus stops. It only happens when I go over speed bumps.. Im getting ready to go on a 2000 mile roadtrip and of course this happens 3 days before I leave! I took a video you can see here
Also the air pump comes on and runs for about 15 seconds after I hit a bump..
I am leaning towards the air bags on the struts. Has anyone had this problem before? Any help is appreciated,
Your video sounds like air escaping from a hose but the pump is coming on to keep it from lowering. Just a wild guess. Before going on a 2,000 mile trip I would have a dealer or an Indy with a STAR system run diagnostics.
I am no expert but within the system is a pressure relief valve that for example you will here when you raise the vehicle or sometimes when you exit the vehicle.
If that valve was weak then a speed bump could cause a sharp release of air which your compressor would compensate for.
I dont think its a leak as such because the pump runs for a short time and then shuts off, so pressure is building back up.
