FIXED! No audio or Climate Control
Myself along with a few others have had the issue of no audio and no climate controls. Personally my issue started after removing my shifter (both at a shop and home). I figured the loss in power and audio was due to the battery jump I attempted.
Fast forward 3 weeks. Yesterday I decided to miss around and figure out where 2 cords belonged. In that process I did the following:
Checked all fuses (10amp blown behind radio)
Removed the center dash (radio, change tray,etc)
I found that the idiots who "attempted" to fix my shifter at the shop attached the wire for the a/c unit and radio in the wrong spot. They look exactly the same. HOWEVER, the CCU wire is solo and the radio wire has a 2nd wire attached.
After switching wires the CCU got power and ac came on and my radio was blasting 😊.
*those other wires I mentioned turned out to be for the airbag light on shifter plate and the other wire is still unknown. Darn funky mechanics!
