help needed please urgently
came out of work yesterday went to open boot and nothing happened but indicator lights kept flashing ,opened car with key blade ,tried key in ignition but it also didn't work ,called r.a.c out they didn't have a clue and just recovered me home .when I got home I replaced the key battery still dead also tried spare key also nothing anyone got any ideas please.
Try taking the battery out of the car and charging it. If it works after a charge I would just go out and purchase a new battery because eventually it is going to cause problems in the future.
Don't try jump starting the car because you might mess up some of the electronics.
'96 SL600, '05 S55 AMG, '06 C230
Battery. These cars need a good, full 12+ volts to operate well. And in my experience, around 13 volts is better. A weak battery looks OK at ~12 volts with a meter but the circuits draw a lot of electrical juice.
Cheers,
Jeff
Cheers,
Jeff
Looking very much like your alarm as gone off and as run the battery down .Just like the other post have said , charge up the battery ,then it should be ok. Another thing is you can charge up from the charge points in the engine depot. Check out your owners manual.
