Lowering link/ module question
Old 07-03-2015, 08:05 PM
IDFWU's Avatar
2005 S500
Exclamation Lowering link/ module question
so I know there are tons of thread on this subject but none really answer my question or either I have failed hard at searching lol .
I am about to order some Ghost lowering links, How low are you guys going (inches, mm) to the point the "visit workshop" alert comes up.
I know ton of you are against riding stupid low, but thats what im going for.
I know it will wear my airmatic struts to disaster faster, but its just a simple solution till I order airrex suspension and add accuair (I know not everybody's taste).
Now lowering link and module, does it kill my battery I read somewhere that the module is always on, can I delete the Automatic speed lowering at speeds?
Can it be done on STAR to delete the automatic lowering if I am just on links?
thanks you,
Old 07-03-2015, 09:15 PM
VMAX7's Avatar
2000 S430, 2000 S500 Both Brilliant Silver!
https://mbworld.org/forums/s-class-w...ml#post6478467
http://m.ebay.com/itm/310406268658?_mwBanner=1
https://mbworld.org/forums/s-class-w...-drop-car.html
Enjoy and do it!
VMAX7's Avatar
Click on these three links^^^
Old 07-03-2015, 09:22 PM
VMAX7's Avatar
Do you have ABC or AirMatic? Specify before ordering.
Old 07-04-2015, 05:04 AM
tusabes's Avatar
Mercedes
This what you want
https://mbworld.org/forums/s-class-w...uspension.html
A fully adjustable control and uses oem parts so it will ride better than any aftermarket air setup
Old 07-04-2015, 03:18 PM
IDFWU's Avatar
2005 S500
I saw that thread where he made that aftermarket box for the suspension, I looks promising but not much information.
The only reason Im going Airrex and accuair bc Airrex is a coilover air bag set up and accuair just suits my lazy needs on raising the car up and down lol
The only reason I willing to spend on lowering links right now bc well... Im not a fan of the 4x4 look lol. and if i decide to get a module it would be the one from loweringmodule.com bc of the price. Renntech is nice but not $1k+ nice since im going to just take that out later on and replace it with aftermarket suspension. So lowering links would work. Im just concern that if I hit a certain speed riding too low it will lower it self more on the highway and scrape like a MF. Thats why im asking what is the lowest some of you guys are running to kinda give me an idea how low i can go with out getting a warning light or scrapin the hell out of my inner fenders by self lowering
I am on airmatic
I stay away from ebay lol
Old 07-04-2015, 04:21 PM
tusabes's Avatar
Mercedes
Does airrex have a coil over setup for the w220? I thought there are no air systems that specifically fit a w220 it's always custom fabrication which rides terrible compAred to stock
I think the best setup is a stock setup you can control manually
Old 07-04-2015, 04:50 PM
VMAX7's Avatar
Ebay is not that bad haha. The links are a simple 2-3mm thick metal rod, 3" long, threaded. with one ball joint at each end which carries NO LOAD.
A caveman can go to home dpot and make a set of links.
Im about a finger thickness height from the top of the tire to the fender at all four corners. Drives like stock, doesnt scrape at all, but I avoid any and all bumps and dips in the road!
Old 07-04-2015, 04:55 PM
VMAX7's Avatar
Agreed
Old 07-04-2015, 05:44 PM
IDFWU's Avatar
2005 S500
Airrex does have a kit for our cars, they jsut raised the prices it was $2800 before now its around $3000 for just the bags/coilovers + another $3000 for airrex management system, or accuair for around $2500
Ive seen a few kits out there for the w220 same with coilovers
Thats what I was considering in doing going to home depo and just making my own but lazyness wins this round, plus I dont think home depo sells the end caps for the pivot point :/
Old 07-04-2015, 05:56 PM
tusabes's Avatar
Mercedes
You can just use washers to lower instead of links
Costs 75 cents. See thread:
Old 07-05-2015, 01:28 PM
IDFWU's Avatar
2005 S500
I need at least a 2.5" drop washer wont do it, my concern is just how low does the car have to be for the visit workshop alert to come on :/
Old 07-05-2015, 02:20 PM
ItalianJoe1's Avatar
2003 CL 600
Well the visit workshop message is when the sensors are too low. Since you are fooling the sensors into thinking that the 2" drop is the "normal" height with links, it won't give the workshop message. ABC cars have a separate travel sensor on the strut but I don't believe an air-matic car does, so it doesn't know the trim height has been adjusted when you just change links because it has no other way to see it.
Old 07-05-2015, 10:17 PM
IDFWU's Avatar
2005 S500
pretty much the answer I needed thank you.
last question !!
so say im lowered that much, I have people in the back do the sensors put the height at what I have it at or will it sag? Also you guys that are lowered to you keep it in comfort, sport 1 or sport 2? I usually ride in sport 2 not sure why I guess I just miss having a race car but even then its really smooth lol
Old 07-06-2015, 10:21 PM
2003 CL 600
It will still compensate for weight, as it will go down a little more so it will pump back up to whatever it's supposed to be at. It still sees how much it's moving around, it just doesn't know that it's "zero" point is different than factory.
Old 07-23-2015, 04:31 AM
Cpt.Joe1983's Avatar
Mercedes s600
lowered mine with lowering links. took me 45 mins to install and i have ZERO skills
Old 08-10-2015, 06:23 PM
rob_fed's Avatar
W204 C300 2010
I'll put in my 2 cents with my airmatic experiences (***)...
*** Errors will not show up if you are "stupid low", make sure your links are adjusted to even lengths to each other. The stock rear link is slotted and adjustable. you can play around with that before you get aftermarket links.
*** Yes probably... But the airmatic strut is most robust than you would think as long as you starting with ones in good condition. For a stock airstrut, the range of adjustment is very wide. It will raise many inches above stock ride height and when deflated, the fenders can cover the entire sidewalls. It should be noted that each strut has an internal bump stop, which you will be riding on if you are "stupid low" The aftermarket systems seem to be popular among other brand enthusiast, if either make a full replacement for the W220, that might make for an interesting swap as long as everything can either eliminate or integrate with the airmatic computer.
*** As you shorten the links, your car will go lower as the it is trying to compensate to keep the height sensor at the designated angle. I supposes if you make the links so short that they somehow bind and damage the height sensor, then your might get strange effect where the suspension cannot adjust, but never heard of anything like that.
*** Auto speed lowering - if you are going to be riding the bumpstops, then it won't matter.
*** Not sure, everything I've done with my airmatic was to work with it, not to change it.
thanks you,
One more thing... What ever you do to lower your car, I would "at least" adjust the "toe" setting to keep the front wheels parallel to each other. A bad toe setting, in combination, with a additional negative camber will eat the inside edges of the front tires very quickly. Good toe with negative camber still wears the inside edges, but bad toe makes for an extreme case. Especially if you going "stupid low".
There seems to be some negative camber built in at stock ride height, at least for my car. Going down 2-3 inches increased my camber to about -4 or -5 degrees. I used the MBZ camber adjustment bolts only on the control arms (some say to do both control and thrust arms) and corrected the toe and the front tires last 2 times longer than the rears. I did not do the rear camber correction, but may do so. The front camber bolts reduced my negative camber to -2 degrees lowered at about 3".
Quick Reply: Lowering link/ module question
