S500 long AMG kompressor
hello
I would need some help with some things .. you will sadly no info about it.
I have a S500 Long as I bought an E55 AMG compressor to which I will mount.
Also the cooling system and large pulley at the crank
What do I need?
all tips are welcome
my car
What do I need?
my car
Welcome to the forum, car is sexy.
However, I havent seen nor heard of anyone bolting an AMG supercharger onto an NA motor sucessfully.
Consensus says its easier to do a complete swap bc it would be hard to get it running and dealing with coding all the parts to work together.
Correct me if im wrong.
That supercharger is clutch operated, only turns on when it needs to. You will need a computer to control the clutch. You will also need a new fuel map and a new fuel pump. Your old fuel pump will forsure not keep up the amount of fuel a supercharged M113 E50 will drink. There's more stuff you need to do as well.
Can't just bolt on an amg supercharger onto a normal engine
Get a kleemann supercharger they are designed to be added to the normal engine and come with the required parts to Adapt it
The supercharged engine is a different engine.
The bottom end is stronger.
The brakes and final drive are definitely uprated, and the transmission probably is.
All sorts of differences. Best way is to buy an S55K.
Sorry.
Nick
Sorry.
Nick
