New headlights
I wouldn't recommend buying anything on eBay . You should buy your hid kit from the installer you will use to install the lights. They should be experienced installing hid kits in Mercedes and warranty their parts and labor .
That way if you get error message or a light dies, you can take it back to them to fix it. If you bring all your own parts , they will not warranty It. Aftermarket hid kits have a very high failure rate so the chance you'll need warranty work is high . Find a good local shop and use the kit they sell , warranty and stand behind
Hey guys, sorry for the postponement of this project, I was busy fixing other problems in my car. Now, it's time to get these headlights installed. I was going to buy this HID kit just now, but I thought I'd get your guys' approval on it before I do buy it. Thank you everyone.
http://www.ebay.com/itm/35W-CANBUS-X...i4obqi4M5qKWpw
SPONSOR/MBworld Guru
Are you saying you don't run your low beams at night at all? Or that you just want to run your high beams normally at night? It got pretty dark at 6pm today in socal so should be running your low beams unless you don't go out at night?
As for those Promax kits.... we have fairly extensive experience with that particular kit as we used to carry them as well before we got tired of constantly processing warranty claims as they have a horrible reliability and didn't want our name associated with that product anymore. I know you mentioned before that you're on a budget.... but you don't want your lights to go out on you at night either... I'd recommend looking for a different budget kit.
Also, are you even 100% sure these headlights will work on this car? Just today, the company that makes these headlights replied someone who asked if it were to fit on their factory HID system, to which they responded: "The headlight harnesses are NOT the same. If you have stock Xenon bulbs, unfortunately these headlights will NOT fit on your vehicle."
It would kinda suck to have all the HID bulbs bought and right as I go to put it on, it doesn't work at all. Can someone please clarify if this will even work?
Yes, you got your lights confused it seems. Fog lights yeah, no one really uses. Low beams are what comes on in auto. High beams you probably also rarely use in the city as well.
Oem xenon bulbs are typically D1S or D2S bulbs which you're not looking for. You're looking for H series HID conversion bulbs.
Yes the eBay seller is correct that the oem hid lights will not fit in these lights
That's why you have to buy the correct aftermarket hid kit . And you keep picking cheap kits that are likely to give you errors . Or flicker, or fail completely . You should get canbus
#32
Let's say I had the best most expensive HID kit and I installed them into the headlights. I go to install the headlights and plug it into the right socket, however, there is still that 5-pin plug that doesn't go anywhere into the new headlights. So there is one plug in the headlight and the other one just dangling. Is that 5-pin plug important? Will that prevent the headlight from working entirely?
#33
A little research will answer your questions.
http://www.benzworld.org/forums/w220...eferences.html
https://mbworld.org/forums/s-class-w...n-upgrade.html
https://mbworld.org/forums/s-class-w...-question.html
http://www.benzworld.org/forums/w220...eadlights.html
There are more threads...
#34
#35
I recently tried installing these headlights. I used an expensive HID kit, but the headlights just did not work. I even tried it without the HID kit on the other headlight, it didn't work either. They tried everything to get it working, and we got nothing in return. There was two plugs: One connected perfectly to the aftermarket's plug and the other one was left hanging with nowhere to go. I'm assuming if the car detects nothing is plugged into that hanging plug, then it will detect that nothing is plugged in at all.
This really sucks. The headlight looked amazing when they were put in the car, they even looked better than the actual 2015 s class headlights! It's disappointing that it didn't work. I guess I'll just wait for the HID compatible version to come out.
#37
I wanted to update this thread. I successfully got the headlights to work with my S600. I didn't even need to put an HID kit in it, I kept the headlights exactly how I got it from the mail. It is very tricky to get the headlights to work with a car that doesn't have the factory halogen system, as it won't work if you just try to plug it in normally or use an HID kit with it. But, I am glad to say, that this is entirely possible. The result is amazing, the car looks like some brand new concept Mercedes-Benz from the front. It no longer looks like a 10+ year old S-Class. I will post some pictures soon.
I will reveal how I got them to work a little bit later.
#42
Looks awesome !! Completely updated the look of the car
Can you please post step by step how you got them to work on a car with factory xenon ? There is another member on benzworld asking to do the exact same thing and i would like to be able to point them to your solution
#43
2000 E430 Sport
So has anyone used these on a halogen car? I need new headlights and I have the standard halogen models. I read a lot of negative comments about poor wiring on theses, they are specd right? Are they truly plug and play? i know they haze easier than stock headlights, I have a buddy who owns a body shop would clearing them help?
#44
Using clear vinyl wrap, like clear bra material will prevent hazing . It also protects from stone chips . I clear wrap all my headlights after I do a headlight restoration to keep them clear and protected
If you have factory halogen lights they should be plug and play
Hopefully Alex will chime in about the wiring as he installed them on his car with factory xenon hid
#46
No errors whatsoever. Not in the dash, not with the headlights themselves, nothing. It is as if you are running the stock headlights.
#47
Can your guy make an adapter cable , that plugs into the Mercedes wiring and plugs into the updated headlights ? That way the wires can be routed correctly and will go to the correct position and it can be plug and play
#48
I have noticed that the other model aftermarket headlights with DRL at the bottom edge (Silver or Black) now have halogen and factory xenon models (non-ABC). Maybe we will get lucky and there will be a factory xenon option for the other model as well.
#50
