Trying to Lower my W220
Old 09-18-2015, 11:32 PM
SmokeyS500's Avatar
2005 Mercedes Benz S500 4Matic
I have 20inch wheels on my W220 and i am thinking of lowering it via lowering links. However in my front wheel wells I have this huge bolt that is right over my 2 front tires. If I was to lower my ride this bolt is going to shread into my tires as soon as I hit a bump. How is everyone getting around this? I have seen MANY W220s lowered but I have no idea how they are stopping that bolt from hitting the tire. Is that bolt static or does it move with the tire (up and down). Or do you have to remove the whole assembly just to lower the front of the car. Thanx for any help given!!
Old 09-19-2015, 12:10 AM
Lifeforce's Avatar
2010 w204 C63 AMG - 1998 S320 - 2008 R350
That bolt is part of the control arm and moves with the suspension. It will not hit your tire. I have 20's and am lowered on links about 3 inches. You'll be good.
Old 09-19-2015, 01:44 AM
SmokeyS500's Avatar
Awesome thats great to hear!! Glad that wont be an issue thank you!! Your car looks clean! Did you use the stock rear links or new all the way around??
Old 09-19-2015, 02:13 AM
Lifeforce's Avatar
Aftermarket front adjustable links. Rear is adjustable the way it's designed from the factory.
Old 09-19-2015, 02:58 AM
IDFWU's Avatar
2005 S500
you will be fine just make sure you dont get a really meaty tire.
Old 09-19-2015, 03:56 AM
SmokeyS500's Avatar
Running a 245/35/20 on the front and a 275/30/20 on the back. Shouldnt have issues with that should I??
Old 09-19-2015, 04:29 PM
IDFWU's Avatar
2005 S500
30/35 series tires you should be fine, I was referring if you go anything like 40/45 series
Old 09-20-2015, 04:17 AM
Welwynnick's Avatar
2006 S600
Hey Lifeforce, I'm curious what size wheels and tires you run?
Cheers, Nick
Quick Reply: Trying to Lower my W220
