Sclass 2005 S600 driver side door/seat switch panel
1 Post
S500 1997 + S600 2005
Driver seat not responding.
My driver side switch moves the mirrors but not the seat. The heat and cool buttons on that panel light up when pressed, but don't stay on. Is there a fuse
for the seat motor??? If so, what number would it be?
Lastly, outside, the driver door closing button for locking does not function, probably all related?. However, the locking buttons on all other doors work fine.
What gives??
What gives??
Same issue happened to me a while ago. Replace the fuse for the driver's seat controls and you're good to go. I don't remember which fuse it was exactly, but it was definitely a fuse under the rear passenger seat fusebox. Check all fuses in that fusebox with a fuse tester and replace any that are blown out or don't work, one of them will definitely be your driver's seat controls fuse and it should start working normally again.
Edit: I believe the fuse number is 64. Hope this helps.
