Possible flexdisk problem.
Old 08-22-2016, 11:04 AM
ultranank's Avatar
W220 S320, W126 380SEC, W111 220SE
My S430 has a problem when changing gears under acceleration. If I gently accelerate, it changes gears smoothly, and likewise does so when it's cold. Once warm, what can best be described as a smooth shudder sometimes occurs when changing gears, there is no "clunk." I replaced the engine and gearbox mounts, because they needed to be done, but that didn't solve the vibration problem. I am waiting for a dipstick to arrive so I can check the auto gearbox oil levels, and quick glance of the flexdisk coupling to the tailshaft looks ok, but I haven't as yet crawled under the car and tested it by prising a screwdriver between the fastening bolts to see if there is cracking in the rubber. Does this problem sound familiar to anyone out there, or could it be a problem with the gearbox?
Richard
Old 08-22-2016, 09:08 PM
jylee's Avatar
14 E350; 12 Camaro; 07 Range Rocer; 06 Dodge Ram
I only changed one flex disk, it was on a w140 at the transmission side. The thread and rubber are almost torn apart. I did not have vibration.
Old 08-24-2016, 07:50 AM
_Ryan's Avatar
2004 S600 Biturbo
Check your trans fluid.
Those flex disks usually last forever. I would definitely check them since it's easy to do but most likely they aren't your problem.
Quick Reply: Possible flexdisk problem.
