diagnostic star tool abc help
So my abc drive carefully warning light came on in red and i was wondering what is my first step to trying to figure out what i should replace ?
Should i take it to the dealer ? will they give me the diagnostic codes ? Should i goto mbstartool.com and buy a diagnostic system there ? which one would i even buy though ?
I kind of want to go in there and just replace then tandem abc pump but what if its the actual compressor ? what if its none of those things ? could be a vavle block or a accumulator.
Any help and suggestions would be much appreaciated. Im not scared to rebuild the abc pump if i have too which seems like thats usually the case. My fluid for abc doesnt seem low at all.
Dear Biff, your solutions go from the foolish to the absurd,and wow I wish I had your money to throw around----do yourself a huge favor call around the foreign repair shops and simply ask if they have diagnostic tools that can read all of the cars modules---someone in Houston has gotta have good diagnostics---then go see him and all you want is a copy of the quick test,which lists all the faults and then you can play mechanic and attempt to fix a very complicate system!!
don't start replacing parts. While it's usually the pump it could be the valve blocks or a strut
Since I plan on owning a mercedes benz car for a while i really dont actually mind learning how to use a star sds over time. Ive had my eclass for almost 10years now and ive never taken it to the mechanic ive always fixed it myself.
I see a bunch of dirt cheap s classes on craigslist. I think it would be awesome to learn how to repair these vehicles over time so I could buy one,fix it and give one to my mom. So im looking at this from a long term point of view. I think i have a guy coming over this weekend who does side work Ill ask him which system I should look into getting or not.
If anyone can still recommend a system to buy please chime in
2016 S63, 2013 SL63
I have the aliexpress setup on XP that works very well. The new ones use W7.
Tiny curve with keygens and a larger curve learning the system.
Anyway, real happy with the aliexpress quality.
https://www.aliexpress.com/item/2015...0-fcf08d633bbc
2004 w220 S500/2008 w164 ML350/2007 Yamaha R1
hey if you want to work on ABC system you definitely need star diag. i have this set up and it works like a charm http://www.ebay.com/itm/For-MB-Star-...-/152011329608 and i had same problems as you did with ABC and my pump was shot so i did rebuilt it but be careful what u getting in to there is a very good write up on here that i used to rebuilt my pump they are very expensive good luck to you sir and keep as up dated ......... and i will try to find the write up for the ABC pump rebuilt and the rebuilt kit is cheap also i belive i paid around 100$ for it
pump,serpentine belts,hydraulic fluid,filters-3,200
even though it was a costly repair the dude had mercy on me lol so i feel i got a very very very good deal at the end of the day
i took it in for a diagnostic and it was the pump. i just ended up letting the mechanic do it.
Ouch! Any time I get an ABC car I will immediately flush the fluid with MB fluid (pentosin will eventually kill the pump because there are no conditioners in that fluid), replace the filters, and replace all 4 of the pressure accumulators (also known as nitrogen spheres) under the car. I will do all of that even if the owner tells me he just did it an hour ago before I came and bought the car. Can never be too careful, and it's not that expensive and you can do it yourself.
That usually alleviates a lots of stress off the pump and will save a dying one from death or bring one with error codes back to life (most of the time). I haven't had to replace an ABC pump yet, and I have had 4 cars with ABC that I beat the absolute snot out of.
