Some error codes I could need some help with
w220 s320 gas
so getting error codes p0300, p0301, p0302, p0303. So basically it tells me the cylinders are misfireing and random missfire. So since it goes on several cyllinders I guess it cant be the 3 wires, coils nor spark plugs, what else could it be that missfires 3 cylinders? and when I erase the codes there are none until I do kickdown and overload the engine.
Try putting some Chevron Techon fuel system cleaner. Pour the entire contents into your gas tank and then fill up the car. Take it on a very brisk drive for about 1/2 hour and see if that has any effect on the misfire.
My symptoms with #7 misfire: a long delay for the engine to start up after I turned the key. Would the fuel pump or the fuel relay caused #7 misfire issue?
I thought so too but I mentioned the relay because it's just weird that I don't have the relay in X. In the fuse chart, it mentions relay in X for 12TT AMG and relay in T for other models.
Is there a 12TT AMG separately from 12TT?
Originally Posted by Jack_88
S65?
The bad fuel cap or bad idle air/speed control valve could also caused misfire right? How likely are they on #7 when the engine is cold?
