S600 trunk won't open or close
Old 11-14-2016, 10:07 PM
Zach8131's Avatar
'12 528i, '05 E320, '05 Jag XJ8L, '04 CLK500, '03 S600, '92 Jeep Briarwood, '79 Rolls Royce
Hey members. I have been having an issue with my trunk not opening on my S600. I have replaced the latch as well as the PSE pump as of today. Both brand new items from the dealer.
I also serviced the hydraulic closing/opening pump by the battery by refilling the reservoir with transmission oil. It was working to close the trunk even though I had to open it with the blade key.
Now as of today when I replaced the PSE pump (pulled the fuse in the rear footwell fuse box and continued replaced the pump) the hydraulic pump isn't working to open or close the trunk anymore AND the latch still won't unlock from the key, button, or driver button. No button is closing the trunk either.
What should I do? I don't have access to stars.
Old 11-15-2016, 01:14 AM
ibeforreal's Avatar
2003 S500 - Toyota Corolla (in the rain)
Have you tried pulling back the insulation/panel covering inside the trunk on the driver's side and checking to see if there is a broken wire?
Old 11-15-2016, 03:01 AM
Zach8131's Avatar
There's currently no carpeting/insulation in my trunk at the moment. All wires are looking good. The only thing I can think of is that an air line is plugged up. If I disconnect the HEK labeled yellow line for the trunk latch, and the yellow air line from the latch itself, should I be able to blow through it?
Old 11-17-2016, 11:29 AM
ibeforreal's Avatar
Have you tried pushing the trunk emergency release button? Maybe it somehow got confused. It is the green circular button on the inside of the trunk lid.
If that doesn't work, try disconnecting the battery for a few minutes and see if it triggers something when reconnected.
Old 12-30-2019, 02:41 AM
Zach8131's Avatar
Just wanted to give an update that the heat from the trunk lights had melted the air hose controlling the trunk latch, and air wasn’t able to pass through. I cut the melted part off and patched it back together with air-hose from my aquarium. So far so good, it’s been a year with no issues.
biker349 (12-30-2019)
Old 01-01-2020, 09:22 AM
Doomore's Avatar
S430 2000, 1996 Chev. Pick-up, 2005 PeterCat
Good job, Zach.
Me, as a Newbie appreciate the follow up on these repairs.
Quick Reply: S600 trunk won't open or close
