Cannot locate fuses for instrument cluster 2002 - S500
Old 12-04-2016, 06:25 PM
kevinrea's Avatar
2002 S500
Hi guys,
I am trying to locate the fuses for my instrument cluster on 2002 S500.
The mechanics manual i have says it is fuses : F79,F84,F85 which are located supposedly in the Cockpit fuse box, which should be on either side of the dash on the ends.
My S500 does not have a fuse box on either end.
I just have a left and right side under the hood and then one under the rear seat on the passenger side.
And of course, the hidden main fuse under the foot area of the front passenger side.
But no fuses F79,F84,F85 anywhere that I can find.
anyone have any ideas ?
thanks very much,
Kevin Rea
Lancaster, Calif.
Old 12-04-2016, 08:35 PM
DrDoe's Avatar
W212 E350; W166 GLC300; W164 ML550; W164 ML63; W221 S65; W220 S430; Escalade ESV
Im not certain but did you try this location?
Old 12-04-2016, 08:36 PM
kevinrea's Avatar
2002 S500
Where is that exactly? I cannot see the picture clearly on my cell phone.
Kevin
Old 12-04-2016, 08:41 PM
DrDoe's Avatar
Dash board. Open passenger door to access
Old 12-04-2016, 08:42 PM
kevinrea's Avatar
2002 S500
Dashboard
Yes I already looked on the end of both sides of the dashboard there's nothing under there but no fuse box.
Quentin Hicks (05-02-2019)
Old 12-04-2016, 10:28 PM
DrDoe's Avatar
There are fuses at that location on the 2004 S430
Old 12-06-2016, 10:36 AM
ibeforreal's Avatar
2003 S500 - Toyota Corolla (in the rain)
The fuses are inside of that closure on the passenger side door. You will need to take a pocket screw drive and pry that cover off.
Old 10-07-2017, 04:14 PM
Andrewblueford's Avatar
2002 S500 Mercedes Benz
Cluster board
My cluster board does not work at all. All gauges is not working either. I need the location of the fuse box and the fuse numders
Old 10-07-2017, 04:36 PM
Cluster board is not working at all
cluster board is completely out. Need fuse numbers to cluster board and location of that fuse box on 2002 s500
Old 10-10-2017, 01:06 PM
ibeforreal's Avatar
Take a look at the picture Dr. Doe posted. Your cluster fuses are inside of that box. There is also the possibility that your instrument cluster is dead. There was a recall several years ago on the instrument cluster dying. Do a search for instrument clusters on this forum. Also, if you are in the USA you can go to the NTSB website and do a search on Mercedes recalls.
Old 11-08-2017, 05:04 PM
alexprokopchik's Avatar
2002 Mercedes S430
Did you figure this out?
Hello Kevin,
I was wondering if you ever found the fuse for the dashboard?
I am having the same issue locating fuses f79-f85.
Thanks!
-Alex
Old 11-08-2017, 08:39 PM
wallyp's Avatar
2003 S500 2007 GL450
Here is the info on fuses for all W220 cars:
http://www.benzworld.org/forums/w220...ml#post8947849
Old 11-08-2017, 10:07 PM
ibeforreal's Avatar
Can't make it any clearer than this. Here is where your instrument cluster, lighter, and other fuses are located.
Old 03-25-2021, 10:13 PM
02s500's Avatar
2002 s500
Actually that’s not in all models I’ve got a 2002 s500 and mine does not have that
This where where the fuse panel is shown if your photo clearly it is not there...
Old 03-26-2021, 10:52 AM
wallyp's Avatar
The dash panel fuse location did not appear until the "facelift" in 2003. All W220 fuse charts should be shown here: https://www.benzworld.org/threads/fu.../#post-8947849
You need the 2000 - 2002 chart.
Quick Reply: Cannot locate fuses for instrument cluster 2002 - S500
